14 years 9 months ago #118981 by parslej
I've read WIKI page.
Enabled option in Configuration but cannot see any option to enter announcement?
14 years 9 months ago - 14 years 9 months ago #118982 by Jiminimonka
Hi parslej,
You probably missed the bit in the wiki that says you have to enter the Joomla ID of the user(s) that can make Announcements.
1) Kunena has built announcements that support bbcode and smileys. Simply turn on announcements in the Kunena admin backend and enter the Joomla User-IDs of that moderators or administrators, who be entitled to write announcements. To enter an announcement select Announcements in the frontend and Add New. That is what we are using here on the site kunena.com. The announcements need a title and you have the choice to fill a short text and a long text, or only the short text.
docs.kunena.org/index.php/Kunena_Announcements
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 9 months ago by Jiminimonka.
14 years 9 months ago - 14 years 9 months ago #118983 by sozzled
G'day, parslej, and welcome to Kunena.
I am guessing - I am taking a wild stab in the dark - that the reason you are having this problem is because you have a Javascript library conflict with Joomla. I am taking a wild stab in the dark that you are using J! 1.5. How can I be sure that I am right when you have not given us any information about your website? That's a good question but, because you have not given us any information (your Kunena configuration report, for example), you have tied our hands in not being able to properly analyse, diagnose and suggest anything better than wild guesses.
I think you will find the answer to your question by reading msg #1 of this topic.
I think that, in future, you should also read How To Ask Questions The Smart Way and What information should I include when I ask for help (including how to post my configuration report)? I hope my guesswork was right and that msg #1 of this topic will help you to resolve your current problems if, as you say, Kunena Announcements in the Wiki did not help you.
Last edit: 14 years 9 months ago by sozzled.
14 years 9 months ago #118986 by mimimike64
Replied by mimimike64 on topic Post(Show) profile
Bonjour,j'utilise joomla 1.5x et virtuemart 1.9 . kunena 1.72. Le bouton affiche le profil n'apparait pas. Il est donc impossible de modifier le profil d'un utilisateur ou d'ajouter des information. J'utilise un template Rokettheme. Merci pour la solution.
Hello, I use joomla 1.5x and virtuemart 1.9. Kunena 1.72. The button posts(shows) the profile does not appear. It is thus impossible to modify the profile of a user or to add information. I use a template Rokettheme. Thank you for the solution.
14 years 9 months ago - 14 years 9 months ago #118990 by fk97440
Hello when i click on the button add add files there is no reaction, no window opening to select files ! I really love kunena and it's the only problem i have.
I would like to be helped to remove this issue, to fix it. I tried to add files with the default template for kunena: same problem.
Thanks by advance,
my website is www.games-humour.eu
Last edit: 14 years 9 months ago by fk97440.
14 years 9 months ago - 14 years 9 months ago #118995 by fyerball72
Replied by fyerball72 on topic Need Help please
Hi.
I have a small website that I have added Joomla 2.5 on. I have downloaded the latest version of Kunena and at first it worked fine. Now the bbCode edit buttons are missing. The smiles do not work. If I try to use my shout box from any forums page it will refresh my page. Also my tabs are missing from the top of the forum and the voting does not work. I have tried a few templates. The default and some new ones. Nothing works.
my site is just a small gamers site for old guys like me. Nothing big but This is killing me I have been trying to fix it for a week.
www.battlebud.com
Last edit: 14 years 9 months ago by fyerball72.
Time to create page: 0.160 seconds
