14 years 9 months ago #116695 by fstltna
Hmm, tried that but it still isn't working... I also put the mootools as the first system plugin, but it didn't do anything
14 years 9 months ago #116697 by CheechDogg
Ok, turn off System - Mootools Upgrade from you plugins, I see that is enabled.
[img
Find me on Facebook.
14 years 9 months ago #116698 by fstltna
I found the cause - the new "TweetBoard Pro" module I installed a couple days ago was screwing it up. I disabed that and the buttons are appearing again...
Marisa
14 years 9 months ago #116699 by CheechDogg
Cool!
[img
14 years 9 months ago #116706 by sozzled
fstltna: please read Legacy mode in the Wiki. Legacy mode is not supported for Joomla; Kunena is not tested on Joomla 1.5.x with legacy mode enabled; K 1.7.1 is not supported for J! 1.5.x sites running legacy mode.
You also have outdated Kunena addons that you should upgrade: Kunena Discuss, Kunena Login, Kunena Search plugin, Kunena Search module, Kunena Stats and Kunena Latest.
The Adrine Dark - Kunena 1.6 template is also quite old - it was designed for K 1.6 - and it is probable that this template should also be updated. Please contact the author of that template for information about its compatibility with K 1.7.1
14 years 9 months ago - 14 years 9 months ago #116727 by ScAArY
I have a problem with the template, because I have a conflict somewhere with js. does not work I curl up on the default category template and emots.
Please help
I have Joomla 1.7.3 and Kunena 1.7.0 and slider. Slider don't work with kunena...
Last edit: 14 years 9 months ago by ScAArY.
Time to create page: 0.159 seconds
