Sticky [Merged topic] How do I restore my Kunena menu?
15 years 8 months ago #81159
by Aventura
Replied by Aventura on topic Re: Menu Buttons missing from the top
Ok cheers, only reason im on 1.6 is because I couldnt get my standard site template to work again in 1.5.
Thanks again
Aventura
Thanks again
Aventura
The topic has been locked.
15 years 8 months ago - 15 years 8 months ago #81169
by Mortti
Replied by Mortti on topic Re: Menu Buttons missing from the top
If you play with J! 1.5.22 and K 1.6.2 there should not be any problems with this.
Before you install Kunena 1.6 - check list
System Requirements
Installing or Upgrading Kunena
Did you test that blend option for your template?
System Requirements
Last edit: 15 years 8 months ago by Mortti.
15 years 8 months ago #81177
by Aventura
The site template wouldn't work properly, conflicted with mootools 1.2.4 - the kunena one was fine (using formality 1.6)
15 years 7 months ago #82024
by bzZ_
Replied by bzZ_ on topic navigation question
I dont know if this is the right section for this question, sry for that..
I installed the Aphotic II template to change the looks of the forum we use.
I recall the navigationbar being visible after I did so, but at this moment it is not.
Is there a setting to activate/deactivate this? Or is it a style issue in this case?
I mean this navigation bar:
thx!
thx!
15 years 7 months ago #82082
by xillibit
Replied by xillibit on topic Re: navigation question
Try Kunena configuration panel -> create menu
Time to create page: 0.249 seconds
