Sticky [Merged topic] How do I restore my Kunena menu?
16 years 4 days ago #71560 by sozzled
Elnablo wrote: I don't have any idea what I did, now everything is working.
I renamen "kunenamenu", could that be a problem?
Looks REALLY NICE now.......
Could that have been a problem? I think you've established that it was the problem.
KISS ... I keep saying it over and over again: keep it simple. Don't try to be too fancy; don't try to be too "clever" ... keep things simple.
The topic has been locked.
15 years 11 months ago - 15 years 10 months ago #73551 by yunie_
I suddenly realise that the whole ktab has gone missing from my forum. ktab refering to the index, recent topics, search bar at the top of the kunena layout.
What could be the reason? I might have taken away the ktab from template editing (seriously im not sure) but even so, i tried changing my template but the tab is still missing.
Last edit: 15 years 10 months ago by sozzled. Reason: Merged from several topics created by one user
15 years 11 months ago #73686 by sozzled
Replied by sozzled on topic Re: whole of ktab missing
In situations where you have changed things (and you've broken something) this is the time when you should consider reverting to a known configuration that works. Reverting to a backup taken (before you made changes) may be the only solution - I don't know for certain because we don't know what changes you have made. Reinstalling Kunena may be another solution. Using the Create Menu function might also help.
Do you know how you got yourself into this situation? Do you have a backup to get yourself out of these troubles?
The following user(s) said Thank You: crebigsol
15 years 11 months ago #73935 by yunie_
Replied by yunie_ on topic Re: whole of ktab missing
i chanced about a few months-old topic and managed to solve the problem - by deleting all kunena menu and creating them again.
thanks again for prompt support. :)
15 years 10 months ago #80005 by DanielSw2
Hey there,
we have a problem with out newest version of kunena.
The menu on the top with the tabs and the log-in form is disappeared.
You can see it here simway.net/forum
We hope that you can help us. Thank you!
Best Regards
15 years 10 months ago #80029 by tbritton
When I went to your page the login form shows up. In regards to the tabs, make sure in the menu manager that you have an entry for Kunena Menu. Then make sure that you have a module called Kunena Menu, it is enabled and the position is set to kunena_menu.
The following user(s) said Thank You: DanielSw2
