Sticky [Merged topic] How do I restore my Kunena menu?
16 years 1 month ago - 16 years 1 month ago #66791
by WorLox
Replied by WorLox on topic Kunena horiz. menu gone
Hey Everyone,
I am designing a new website toghether with Kunena 1.6.
I also decided to make my own template, however i got a small problem.
I have lost my top menu above the user info on the top of the Forum.
I have allready gone crazy trying to find where this i comming from.
Is it a setting in the software, or have i deleted a CSS rule, wich makes this menu.
So if anyone of you guys can tell me how i can restore it would be super.
You can check the forum at: www.spuij-design.com
(note: we are still very busy building this website, so its a bit untidy at the moment)
Last edit: 16 years 1 month ago by WorLox.
The topic has been locked.
16 years 1 month ago #66829
by xillibit
Replied by xillibit on topic Kunena horiz. menu gone
go into kunena control panel and use the function create menu.
The following user(s) said Thank You: WorLox
16 years 1 month ago #66861
by WorLox
Yep found it,
I dont know how, but the menu that is created at install, was deleted.
Thanks for your reply
16 years 1 month ago #67145
by Topaz
Replied by Topaz on topic Kunena horiz. menu gone
16 years 1 month ago #67257
by Topaz
The image in the Template select menu shows that the Template has tabs but they do not show up. I would prefer not to have an extra menu in my site. How can I get the tabs to show ?
16 years 1 month ago #67263
by Gipa
Replied by Gipa on topic Kunena horiz. menu gone
Did you check that your menu item (in your regular site-menu) that is linking to the forum, points to "index" and not to "forum"...?
(See my previous posts in this thread...)
