Sticky [Merged topic] How do I restore my Kunena menu?
- PaRaDiSiAk
- Junior Member
- NO LONGER USED - DELETE THIS ACCOUNT PLEASE
OK no problem, i understand what you say.
It's make a long time that I use and test all versions of Kunena.
I'm now testing this 1.6 beta "in real condition".
I have now understand what are the mootools used for.
I have desactivated the components who needs legacy mode activated, and then i turned off the legacy mode.
I have reinstalled Kunena 1.6 beta 1 and I have the same error.
I'm not (only) here for support, I'm here to understand things and to test Kunena (too), because I like this Forum. If you think that the error I have will not help you, i'll understand.
If so, please ignore my post !
...and excuse me for my poor english...
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Disabled | htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 10M
Kunena version detailled: Installed version: 1.6.0-BETA1 | Build: 3068 | Version name: | Kunena detailled configuration:
board_title Forum 100% Gwada ! board_offline 0 offline_message <h2>Le forum est en maintenance.</h2>
Repassez plus tard !enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 10 messages_per_page_search 20 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template default showannouncement 1 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 900 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 128 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 0 allowavatargallery 0 imageprocessor gd2 avatarquality 75 avatarsize 4096 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 256 allowfileupload 0 allowfileregupload 1 filetypes rar,zip,dmg,txt,doc,pdf filesize 256 showranking 1 rankimages 1 avatar_src cb fb_profile cb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory 84,83,132,13,5,122,7,17,130,18,1,15,8,129,103,95,20,102,97,16,104,101,99,98,100,89 showstats 1 showwhoisonline 0 showgenstats 0 showpopuserstats 1 popusercount 10 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 rules_infb 0 rules_cid 1 rules_link help_infb 0 help_cid 1 help_link www.kunena.com/ showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode fr-fr fbsessiontimeout 1800 highlightcode 0 rss_type thread rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories 84,12 rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_word_count 0 rss_old_titles 1 fbdefaultpage categories default_sort asc alphauserpoints 0 alphauserpointsrules 0 alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system old_ord post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login communitybuilder integration_avatar communitybuilder integration_profile communitybuilder integration_private uddeim integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankysoustats 1 popthankscount 5 mod_see_deleted 0
As I've written before, this "install-Kunena-then-need-to-recreate-menu" problem is a headache. It requires perseverance and patience ... and it can be a struggle. We're working to improve things.
You cannot see the Kunena menu. You have trashed the menu, deleted the trash, used the Kunena control panel to recreate the Kunena menu - and you may have done this twice, three or even fours times - and you still cannot see the Kunena menu on your website. Quel dommage!
I will ask one of the other members of the team to suggest a workaround for your problem.
- PaRaDiSiAk
- Junior Member
I think I'll try perseverance and patience... But before I think that i'm going to take 1000mg Paracetamol for the headache caused by this menu to my poor brain...
Have a good night / nice day !
1. Check in Joomla Menu Manager -> Main Menu(Menu Principal). Does there exist menu with name "Forum"? This one should be deleted! Purged from Trash. And after that you can click button "Create Menu" in Kunena Configuration
2. If first dont help, as error say, have you enabled debug in Joomla and Kunena to see what errors show? Also look to Apache Error Log file if there exist some error.
If you find something report here.
Thank you.
- PaRaDiSiAk
- Junior Member
Debug :
Profil d'information
Application afterLoad: 0.002 seconds, 0.33 MB
Application afterInitialise: 0.118 seconds, 2.69 MB
Application afterRoute: 0.119 seconds, 2.74 MB
Application afterDispatch: 0.457 seconds, 11.00 MB
Application afterRender: 0.575 seconds, 11.69 MB
Occupation mémoire
12369736
6 requêtes envoyées
1.
SELECT *
FROM jos_session
WHERE session_id = '48f16325781ac0218dda7a0694550f40'
2.
DELETE
FROM jos_session
WHERE ( time < '1280452287' )
3.
SELECT *
FROM jos_session
4.
UPDATE `jos_session`
SET `time`='1280459487',`userid`='62',`usertype`='Super Administrator',`username`='Thomas',`gid`='25',`guest`='0',`client_id`='1',`data`='__default|a:8:{s:15:\"session.counter\";i:769;s:19:\"session.timer.start\";i:1280436404;s:18:\"session.timer.last\";i:1280459475;s:17:\"session.timer.now\";i:1280459480;s:22:\"session.client.browser\";s:85:\"Mozilla/5.0 (Windows; U; Windows NT 6.1; fr; rv:1.9.2.Gecko/20100722 Firefox/3.6.8\";s:8:\"registry\";O:9:\"JRegistry\"
:{s:17:\"_defaultNameSpace\";s:7:\"session\";s:9:\"_registry\";a:9:{s:7:\"session\";a:1:{s:4:\"data\";O:8:\"stdClass\":11:{s:23:\"com_modulesfilter_order\";s:10:\"m.position\";s:27:\"com_modulesfilter_order_Dir\";s:0:\"\";s:23:\"com_modulesfilter_state\";s:0:\"\";s:26:\"com_modulesfilter_position\";s:1:\"0\";s:22:\"com_modulesfilter_type\";s:1:\"0\";s:26:\"com_modulesfilter_assigned\";s:1:\"0\";s:17:\"com_modulessearch\";s:0:\"\";s:21:\"searchcom_comprofiler\";s:0:\"\";s:29:\"viewcom_comprofilerlimitstart\";i:0;s:29:\"viewcom_comprofilerlastCBlist\";s:11:\"showplugins\";s:26:\"filter_typecom_comprofiler\";s:1:\"0\";}}s:11:\"application\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:4:\"lang\";s:0:\"\";}}s:6:\"global\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:4:\"list\";O:8:\"stdClass\":1:{s:5:\"limit\";s:3:\"100\";}}}s:11:\"com_modules\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:10:\"limitstart\";i:0;}}s:13:\"com_installer\";a:1:{s:4:\"data\";O:8:\"stdClass\"
:{s:10:\"limitstart\";O:8:\"stdClass\":4:{s:6:\"module\";i:0;s:6:\"plugin\";i:0;s:8:\"template\";i:0;s:9:\"component\";i:0;}s:7:\"modules\";O:8:\"stdClass\":1:{s:6:\"client\";s:2:\"-1\";}s:7:\"plugins\";O:8:\"stdClass\":1:{s:5:\"group\";s:0:\"\";}}}s:11:\"com_plugins\";a:1:{s:4:\"data\";O:8:\"stdClass\":2:{s:4:\"site\";O:8:\"stdClass\":5:{s:12:\"filter_order\";s:8:\"p.folder\";s:16:\"filter_order_Dir\";s:0:\"\";s:12:\"filter_state\";s:0:\"\";s:11:\"filter_type\";s:1:\"1\";s:6:\"search\";s:0:\"\";}s:10:\"limitstart\";i:0;}}s:9:\"com_cache\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:10:\"limitstart\";s:1:\"0\";}}s:9:\"com_menus\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:8:\"menutype\";s:8:\"mainmenu\";}}s:10:\"com_kunena\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:7:\"install\";O:8:\"stdClass\"
:{s:4:\"step\";i:0;s:6:\"status\";a:7:{i:0;a:4:{s:4:\"step\";i:1;s:4:\"task\";s:30:\"Préparation de l\'installation\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:1;a:4:{s:4:\"step\";i:2;s:4:\"task\";s:24:\"Décompression admin.zip\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:2;a:4:{s:4:\"step\";i:2;s:4:\"task\";s:23:\"Décompression site.zip\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:3;a:4:{s:4:\"step\";i:2;s:4:\"task\";s:24:\"Décompression media.zip\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:4;a:4:{s:4:\"step\";i:3;s:4:\"task\";s:33:\"Activation du Plugin Mootools 1.2\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:5;a:4:{s:4:\"step\";i:4;s:4:\"task\";s:22:\"Include sampledata.php\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}i:6;a:4:{s:4:\"step\";i:5;s:4:\"task\";s:37:\"Installation réalisée avec succés!\";s:7:\"success\";b:1;s:3:\"msg\";s:0:\"\";}}s:4:\"task\";i:0;}}}}s:7:\"_errors\";a:0:{}}s:4:\"user\";O:5:\"JUser\":19:{s:2:\"id\";s:2:\"62\";s:4:\"name\";s:6:\"Thomas\";s:8:\"username\";s:6:\"Thomas\";s:5:\"email\";s:29:\"***@***.fr\";s:8:\"password\";s:65:\"***:***\";s:14:\"password_clear\";s:0:\"\";s:8:\"usertype\";s:19:\"Super Administrator\";s:5:\"block\";s:1:\"0\";s:9:\"sendEmail\";s:1:\"1\";s:3:\"gid\";s:2:\"25\";s:12:\"registerDate\";s:19:\"2005-03-29 23:25:00\";s:13:\"lastvisitDate\";s:19:\"2010-07-29 20:46:56\";s:10:\"activation\";s:0:\"\";s:6:\"params\";s:56:\"admin_language=\nlanguage=\neditor=\nhelpsite=\ntimezone=1\n\n\";s:3:\"aid\";i:2;s:5:\"guest\";i:0;s:7:\"_params\";O:10:\"JParameter\":7:{s:4:\"_raw\";s:0:\"\";s:4:\"_xml\";N;s:9:\"_elements\";a:0:{}s:12:\"_elementPath\";a:1:{i:0;s:58:\"/htdocs/public/www/libraries/joomla/html/parameter/element\";}s:17:\"_defaultNameSpace\";s:8:\"_default\";s:9:\"_registry\";a:1:{s:8:\"_default\";a:1:{s:4:\"data\";O:8:\"stdClass\":5:{s:14:\"admin_language\";s:0:\"\";s:8:\"language\";s:0:\"\";s:6:\"editor\";s:0:\"\";s:8:\"helpsite\";s:0:\"\";s:8:\"timezone\";s:1:\"1\";}}}s:7:\"_errors\";a:0:{}}s:9:\"_errorMsg\";N;s:7:\"_errors\";a:0:{}}s:13:\"session.token\";s:32:\"ab98adf8f246266366bdc5f23f5427a2\";}'
WHERE session_id='48f16325781ac0218dda7a0694550f40'
5.
SELECT *
FROM jos_components
WHERE parent = 0
6.
SELECT folder AS type, element AS name, params
FROM jos_plugins
WHERE published >= 1
AND access <= 2
ORDER BY ordering
Fichiers langue chargés
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.plg_system_debug.ini 1
* /htdocs/public/www/language/fr-FR/fr-FR.com_jcomments.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_kunena.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_kunena.ini
* /htdocs/public/www/components/com_kunena/language/fr-FR/fr-FR.com_kunena.ini 1
* /htdocs/public/www/administrator/components/com_kunena/language/fr-FR/fr-FR.com_kunena.ini 1
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_kunena.install.ini 1
* /htdocs/public/www/administrator/components/com_kunena/language/en-GB/en-GB.com_kunena.install.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_kunena.install.ini 1
* /htdocs/public/www/administrator/components/com_kunena/language/fr-FR/fr-FR.com_kunena.install.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.tpl_khepri.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_submenu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_kunena.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_kunena.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_title.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_toolbar.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_groupjive.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_groupjive.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_communicator.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_comprofiler.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_comprofiler.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_adsmanager.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_adsmanager.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_contact.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_eventlist.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_eventlist.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_eweather.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_eweather.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_jcomments.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_poll.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_search.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_shoutbox.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_shoutbox.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_uddeim.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_uddeim.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_xmap.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_xmap.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_zoo.menu.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.com_zoo.menu.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_banners.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_newsfeeds.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.com_weblinks.menu.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_cb_adminnav.ini
* /htdocs/public/www/administrator/language/en-GB/en-GB.mod_cb_adminnav.ini
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.mod_status.ini 1
* /htdocs/public/www/administrator/language/fr-FR/fr-FR.plg_system_jvc.ini 1
Diagnostic des phrases non traduites
Aucun
Phrase non traduite
Aucun
I don't know how to access the apache error log...
I'll ask my host tomorrow on how to access the apache error log... i'm tired... It's 05:20am in France !!!
One issue: I've lost the Kunena horizontal menu bar. Regenerating by clicking on "Create menu" button now adds "Forum" as the first item on my site's main menu, where it is not supposed to be. If I click on the new "Forum" entry, it brings me to my Kunena forum, but the Kunena horizontal menu still isn't appearing.
Any ideas what might be going wrong here?
Thanks again.
-Colin
