Sticky [Merged topic] How do I restore my Kunena menu?
14 years 5 months ago #126619 by cassy79
Replied by cassy79 on topic Seo & Kunena 1.7.2
rejudice. I upgraded to the latest version of Kunena but "after" I activated the seo in joomla 1.5. The result is that I see the homepage of the forum but do not see the categories and posts. That is, it gives me error 400 on the site ... How can you solve?
The topic has been locked.
14 years 5 months ago #126643 by sozzled
G'day, cassy79, and welcome to Kunena.
I am guessing that you made some custom changes to your Joomla menu items and that is why you are now getting 40x errors. The simplest suggestions are
(1) Review your SEO settings against our Search Engine Optimisation (SEO) guide; and
(2) Restore your Kunena menu in the ways described in this topic.
I hope this helps. :)
14 years 4 months ago #127357 by arosscpa
:S Thanks for the helpful hint, Deepmillfarm. I am having a problem, however. I needed to restore my menu tabs, but before I did so I decided to install Kunena 2.0, in case that self-corrected the menu problem on its own. ( It did not, and I admit in retrospect that was stupidly optimistic.) So I went through the procedure in the FAQ and your post. Problem: I cannot find the "Create Menu" feature in the Kunena control panel. I went to Menu Manager in "Forum Tools". Its function appears to be checking for conflict that would inhibit the creation of Kunena menus, but does not generate the menus as 1.7 did? Is this a problem in 2.0, or have I been staring at the screen too long, again.
Thanks,
Aross
14 years 4 months ago #127358 by sozzled
Please keep K 2.0 issues separate from K 1.7 issues. Restoring the Kunena menu in K 2.0 is done differently to the way it is described in this topic, in K 1.7. I am not splitting this topic. Instead, I am locking this topic to prevent further misuse.
