Sticky [Merged topic] How do I restore my Kunena menu?
14 years 5 months ago #120855 by CheechDogg
Can you please post your forums configuration report carlbeck?
[img
Find me on Facebook.
The topic has been locked.
14 years 5 months ago #120856 by carlbeck
I think this is what you ask for:
htaccess: Missing | PHP environment: Max execution time: 240 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : jsn_dome_pro | author: JoomlaShine.com | version: 2.3.0 | creationdate: 02/17/2012
14 years 5 months ago #120857 by CheechDogg
Ok Mr. Carlbeck please do this.
Go to your backend, go to your Kunena's control panel and recreate your menu. You don't have a menu created right now and that is what is giving you that error.
[img
14 years 5 months ago #120862 by carlbeck
OK I found an item in Kunens control panel. Clicked on it and got this: 500 - An error has occurred. Another menu item has the same alias in Root. Root is the top level parent
I mentioned this is an early post: On joomla control panel I click in Menues: I see: "main Menu and Kunena menue. When I click on Kunena menu: There are no menus shown. I deleated the Kunens menu and went back to the Kunens control panel and clicked "Create Menu" again and got the same error as above: 500 error
14 years 5 months ago #120865 by CheechDogg
Ok so we are good.
Make sure you go to the kunena menu trash and delete the menus that are in there, this is what is causing the error. Once you delete those items from the trash you will be good to go!
[img
14 years 5 months ago #120866 by carlbeck
As I said in my last post: There are no menus when I click "Kunens Menu" in joomla Control Panel. Is "kunens menu trash" a clickable icon someplace?
Time to create page: 0.260 seconds
