Sticky [Merged topic] How do I restore my Kunena menu?
14 years 8 months ago - 14 years 8 months ago #118399 by sbirulino
hello Kunena menu is not visible, i haven't deleted it, by mistake i have changed position and now there is'n't, but is published how carryover at the beginning
ciao il menu di kunena non è visibile, per errore l'ho spostato in altra posizione ed ora non c'è più, ma è pubblicato come lo riporto alla posizione iniziale.
thanks.
grazie.
Last edit: 14 years 8 months ago by sbirulino.
The topic has been locked.
14 years 8 months ago #118401 by Jiminimonka
Using the search feature is highly recommended.
www.kunena.org/forum/159-K-17-Common-Que...my-Kunena-menu#53174
Please read the FAQ.
Only one question per topic.
14 years 8 months ago #118413 by sbirulino
ok thanck's I have create a new menu for kunena
14 years 8 months ago #118491 by bjarne_s
Replied by bjarne_s on topic Kunena Menu is not shown
htaccess: Exists | PHP environment: Max execution time: 40 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : gk_twn2 | author: GavickPro | version: 2.5 | creationdate: 05 Dec 2012
Third-party components: Jomsocial 2.4.1
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
The Kunena Menu will not be shown. I have followed the advice in the FAQ, I have checked the DB for dublicate aliases, I have tried to create en new menu ect. ect. but nothing helps. The Kunena Menu will not be shown. I am stucked. Any ideas?
Bjarne
14 years 8 months ago #118495 by Jiminimonka
Do you have the module Kunena Menu enabled?
14 years 8 months ago #118499 by bjarne_s
Yes - I do.
Time to create page: 0.167 seconds
