Sticky [Merged topic] How do I restore my Kunena menu?
14 years 10 months ago #114080 by hunnchback
Hey guys,
I have this very strange problem, I can see my menu on this page:
fishing-sailing-ideas.holidayyachtcharte...t-forums/main-forum/
but when I click on "Welcome mat"
fishing-sailing-ideas.holidayyachtcharte...dex.php/welcome-mat/
it doesnt show up .. can you guys please help me too??
Many thanks,
Hass
I hope its ok to add my urls.
The topic has been locked.
14 years 10 months ago #114082 by 810
On kunena backend click on create menu.
Regards 810
14 years 10 months ago - 14 years 10 months ago #114097 by shintaku
I am NEW hear, using K 1.7. I have this problem of showing my kunena menus on the categories I have created. Anyone with idea to fix this?
I need help in fixing this. Thanks in advance
Last edit: 14 years 10 months ago by shintaku.
14 years 10 months ago #114109 by shintaku
Ok, I found the solution. I just enabled the Kunena SEO (Search Engine Friendly URLs) to "YES" and that worked for me.
14 years 9 months ago #114592 by deepmillfarm
I had the Kunena working - I installed CB and integrated it, so it creates categories when a user logs on for a particular group and the form posts appear in the users profile..
now when a user logs on the forum is display with the index,recent topics,new topics... tabs along the top.
I feel dumb but I can't find what disable or enables the tabs?
help?
see www.spinningmoon.com forum link on the left.
I'm running the latest of everything.. Kunena 1.71, Joomla 1.71, CB 1.71
the Kunena confige settigns are:
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 20M
Joomla default template details : 7degrv1 | author: | version: 1.0 | creationdate: 2011-12-31
Kunena default template details : Blue Eagle (default) | author: Kunena Team | version: 1.7.1 | creationdate: 2011-11-16
Third-party components: CommunityBuilder 1.7.1
14 years 9 months ago #114595 by deepmillfarm
- ok fixed it - I actually serached the Forum and found a set of command to restore it.
which are reproduce below for others:
How do I restore my Kunena menu?[2]
The Kunena menu is a set of tabs that appears across the top of the forum pages. In some cases, this menu does not appear for a variety of causes.
A simple remedy for the problem is to use the trash-burn-build technique:
Trash all existing menus and menu items that relate to your Kunena forum
Ensure that you do not have a folder named /forum on your site.
Empty the menu trash.
Use the Create Menu feature in the Kunena control panel to restore your Kunena menu.
Make sure that you publish a link in your menu that calls the Kunena forum.
Ensure that you have published a menu module for the kunenamenu template position.
Time to create page: 0.146 seconds
