Sticky [Merged topic] How do I restore my Kunena menu?
15 years 2 weeks ago #110683 by sozzled
The following user(s) said Thank You: perpetuo
The topic has been locked.
15 years 2 weeks ago #110705 by perpetuo
sozzled wrote: G'day, perpetuo, and welcome to Kunena.
See How do I restore my Kunena menu?
Thank you,
But I've done it and continue with the same problem.
You can not put a few images with the settings?
15 years 2 weeks ago - 15 years 2 weeks ago #110725 by sozzled
Maybe, one day, when I don't have much else to do, I might make a video of how to do this. It takes about 2 minutes. You trash all of your existing Kunena menu items (using the Joomla Menu Manager); you permanently delete everything in the menu trash (assuming you are using J! 1.5) and then you run the Create Menu feature from the Kunena control panel. The only other thing that you might have to do, is to enable the menu item that's created for you in your main menu module. That's about all there is to it.
On the other hand, if you would like me to do this for you, I can (for a very small fee) ... but that's up to you.
This is a Joomla problem; it's not actually a Kunena problem. The solution is to follow the instructions in How do I restore my Kunena menu? or, if that's too difficult for you, pay someone else who knows their way around the Joomla menu system.
Last edit: 15 years 2 weeks ago by sozzled.
15 years 2 weeks ago #110788 by perpetuo
Thanks, but I solved the problem.
15 years 1 week ago #111389 by theopulencegrop
when I click of the forum that's installed on my site. This is the message that appears:
Warning: Using direct link to Kunena component. No suitable menu item found
Can someone suggest how to fix this? Thanks.
15 years 1 week ago #111477 by Matias
@theopulencegrop: Do you have menu called "Kunena Menu" (or translated version of it)? Do you have all the items published in it? The message comes if Kunena doesn't find suitable menu item.
Time to create page: 0.154 seconds
