Sticky [Merged topic] How do I restore my Kunena menu?
15 years 1 month ago #109661
Replied by sozzled on topic Re: Link to /forum not working
I will look into this later. I suggest that you read again the link that I posted in my earlier reply. It's quite possible that the .htaccess file that you're using may be old or customised and it would be a good idea to replace it with the standard file that ships with Joomla (as htaccess.txt which you have to rename). Also I don't think it adds anything to your website if your pages have a .html suffix (so I would turn off that option).
The topic has been locked.
- Watty80_99
15 years 1 month ago #109662
by Watty80_99
Replied by Watty80_99 on topic Re: Link to /forum not working
I'll do both of those, thanks.
15 years 1 month ago - 15 years 1 month ago #109664
I think I've figured out why your links aren't working and why you're getting 404 errors. Most of the time, these things are caused by not properly setting up the Kunena menu. There is a guide in the FAQs page to how you should do this. It involves a technique that we sometimes refer to as the "trash-burn-build" approach. You trash your existing menu items that have links to Kunena, delete them from the menu trash, and use the Kunena Create Menu function in the backend. This, almost certainly, should fix your problem.
See How do I restore my Kunena menu?
Last edit: 15 years 1 month ago by sozzled.
- Watty80_99
15 years 1 month ago #109697
by Watty80_99
Thank you, that seems to have done the trick. Now going through my notes to find out what I did to mess it up!
15 years 2 weeks ago - 15 years 2 weeks ago #110669
by f0CUS
Replied by f0CUS on topic Re: Link to /forum not working
nvm, got it
Last edit: 15 years 2 weeks ago by f0CUS.
