Sticky [Merged topic] How do I restore my Kunena menu?
15 years 3 months ago - 15 years 3 months ago #104927 by kunenamies
I think you summarized it quite OK but let me clarify:
Kunena Forum as such works fine when I enter it by selecting the Kunena menu. I see all Kunena menu items and the forum works as it should. I can go to the topic that has been selected for Kunena Discuss to allow quick commenting directly from the selected articles (categories) and they work just fine and all Kunena menus work as they should.
However, if I go to an article that somebody has commented and I now see the link "Discuss this article in the forums" and I click that => the system takes me to the right place (i enter Kunena Forum and I see the topic) but I do not see the Kunena main menus at all.
I think I have followed the guidelines but I will double check tomorrow.
And you are right: This might not be a Kunena Discuss issue at all. It just sounded like a logical place to start.
The config is attached and thank you so much for looking into this...
Joomla default template details : my_domain_template_1 | author: My Domain | version: 2.0.4 | creationdate: 01-21-2011
Third-party components: CommunityBuilder 1.7
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4 | Kunena Stats 1.6.4
Last edit: 15 years 3 months ago by sozzled. Reason: Reveal K 1.6 configuration report in message
The topic has been locked.
15 years 3 months ago #104928 by sozzled
Thank you for your config. report. Your report shows that you have not correctly setup your Kunena menu according to the guides that are published on that issue. I have merged this topic with another topic that deals with this broader issue of how to setup your Kunena menu. On this basis, this question is not specifically related to a problem introduced specifically by the Kunena Discuss plugin but goes to the heart of how to set up the Kunena menu properly in the first place.
When you have properly set up the Kunena menu properly it will work regardless of how you access your forum.
The following user(s) said Thank You: kunenamies
15 years 3 months ago #104935 by Matias
@kunenaäijä:
I can also see that you have multi-language environment in your site? Kunena 1.6 is lacking support for Joomla multi-language menus (it was added into k1.7.0).
15 years 3 months ago - 15 years 3 months ago #105003 by kunenamies
I do have multi-language environment but Kunena (menus etc. where language can actually be set) is set to "All" so it works in its native language still. However, I have translated the Kunena menu titles to the local language thinking that that does not hurt but I think I have probably done a bit too much there and I now tried to reconstruct the menus as instructed => Everything works as it should! Sorry, should have tried that as the first thing but it did not occur to me since Kunena seemed to work just fine. Live and learn.
Cannot wait for Kunena 1.7 and the new Kunena Discuss and proper language support.
Btw, is it OK to change the Kunena menu label names without affecting Kunena functionality?
And I am very grateful for the support!
Last edit: 15 years 3 months ago by kunenamies. Reason: Rebuild the menus and it worked!
15 years 3 months ago #105123 by Matias
Menu items are just menu items.. Nothing more.
The multi-language support in K1.7 for Kunena works by adding all languages into the same Kunena Menu. Just don't use All after you add the language support as it probably messes things up.
15 years 2 months ago - 15 years 2 months ago #105438 by kimba
I'm not sure if anyone else has the same problem here.
I've been able to successfully enable to the Kunena menu on frontend but when I try to select a single category or a topic, the menu completely disappears. What might be causing this?
Last edit: 15 years 2 months ago by kimba.
Time to create page: 0.159 seconds
