Sticky [Merged topic] How do I restore my Kunena menu?
14 years 7 months ago #122025
by Mr.C
Replied by Mr.C on topic Re: [Merged topic] How do I restore my Kunena menu?
I found what you meant. It was published with a different name in the same position. Thank you very much.
I didn't mean to sound condescending, in my other reply. I was looking for what you showed in the photo, which lead me to look for a menu with the 2 in it's name... my mistake and again, I apologize if my response lead you to believe I was being rude or anything. Was not my intention...
The topic has been locked.
14 years 7 months ago - 14 years 7 months ago #123076
by adam
Replied by adam on topic New installation of K 1.7.0: only option is "Install Kunena 1.6"!
I installed kunena and every thing is true . but how can i see the forum ?? or how can I add it to the main menu ???? thanks
Last edit: 14 years 7 months ago by adam.
14 years 7 months ago #123081
Replied by sozzled on topic [Merged topic] How do I restore my Kunena menu?
G'day, adam, and welcome to Kunena.
The answer to your frequently-asked question is to use the FAQs menu tab, located in the menu at the top of the forum here, as read the tips given in How do I restore my Kunena menu? as well as other advice given in this topic. I hope this helps.
The following user(s) said Thank You: adam
14 years 7 months ago #123117
by adam
Replied by adam on topic [Merged topic] How do I restore my Kunena menu?
thank you very much i made fixed it..
- juannicolas
- Thank you received: 1
14 years 6 months ago #123644
by juannicolas
Replied by juannicolas on topic Change colour of Kunena menu tabs
Hello, I don't know if I can ask this here but since your a talking about the top menu colors and I have search in the forum for a quite while and found nothing or maybe searching the wrong terms. But i installed 1.7.2 on Joomla 1.5.25 and for some reason or lack of configuration knowledge my top menu icons does not appears, I only the a line text menu links. I would appreciate any help with this.
14 years 6 months ago #123662
G'day, juannicolas, and welcome to Kunena.
You did ask your question in the wrong place but I have merged your post with this topic which answers your question. See the message I wrote, two messages before yours.
The following user(s) said Thank You: juannicolas
Time to create page: 0.157 seconds
