Sticky [Merged topic] How do I restore my Kunena menu?
15 years 9 months ago - 15 years 9 months ago #71359 by Elnablo
I am using newest JOOMLA & KUNENA. I have a really strange effect,
that the menubuttons in my Tab menu (INDEX, Recent Topics, etc)
above the forum just disappear.
If I set the moduls parameter to "Vorgängerversion - Hotizontal" everything
works and the menü is displayed at all times. Just looks really :sick:
"Vorgängerversion - Hotizontal" means something like "Previous version - horizontal"
in english.
Read somewhere, that System - Mootools should be upgraded, but that does
not help.
Thanks in advance for your help,
Robert
PS: Have tried 5 other templates, no difference!!!
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 80M | Max file upload: 8M
Joomla default template details : wds_car_desing_13 | author: www.templatki.com | version: 1.0 | creationdate: 2010-04-23
Last edit: 15 years 9 months ago by Elnablo.
The topic has been locked.
15 years 9 months ago - 15 years 9 months ago #71372 by Elnablo
As far as I can read up in this forum, this is supposedly a mootools problem.
Well, I don't believe that to be so, beause the BBCode buttons of the editor do work and my
editor looks and works just like the editor here on site. If I read up correctly, this would
not be possible with the wrong mootools installed.
Also, the menu tabs do show sometimes and then I click into a topic and they are gone.
Using the back-arrow in the browser moves me back up, and the tab menu magically reapears.
So I'm betting there is a tiny error somewhere in the KUNENA code, right? If it would
never work under KUNENA, than I would believe the mootools theory. But since the tab
buttons do show up on certain pages of my KUNENA forum, it has got to be a coding error
or "undokumented feature". :ohmy:
Seems logical to me, right?
15 years 9 months ago #71427 by sozzled
The Kunena menu is unrelated to Mootools. The Kunena menu is just a Joomla menu. See Customised Menus in the Wiki for further information.
The latest version of Joomla is J! 1.5.22.
To re-establish your Kunena menu, use the Create Menu option on your Kunena control panel.
15 years 9 months ago - 15 years 9 months ago #71466 by Elnablo
Maybe I didn't explain myself correctly.
See the foto below, that's the best I can do. I did have the large
Buttons for a while, but they don't work everywhere. For instance
they would just disappear, as soon as I clicked on a topic.
As fas as I can tell, it is a problem with KUNENA, because how else
can it be explained, that the buttons just disappear when changing
to a different part of KUNENA?
Using the very "ugly" buttons below, I at least don't loose my menu :sick:
along the way. Sure isn't pretty though!! So as soon as I change the
modul parameter to "List", I get a mess.
I can set up an example for you if you like. Will install 1.5.22,
as I am still on 1.5.21. 1.5.22 did not change anything.....
Also the "Mark all as read.." does not work properly. The text
only appears, when the mouse is moved across the button.
Thanks for your help,
Robert
[attachment:1]Kategorien - Main11 Forum-1.jpg[/attachment]
15 years 9 months ago #71522 by sozzled
I've seen this problem before - many times before - and every time I've seen it, these problems are caused by the site template.
What is more, every one of these problems that I have seen before has been generated because the user had an Artiseer-designed/developed template. Here is one such problem that I assisted a user with. I am not saying that it will necessarily solve all of your problems but I am saying that it shows that the problems are not caused by Kunena.
See the very long and involved discussion: Weird layout in profile section . We solved the problem. It took nearly three weeks of intensive digging around.
Your missing BBcode toolbar is caused by a Javascript conflict. The Javascript conflict may, or may not, be caused by something needed by your site template (the menu, perhaps)? I would also suspect that when you try to edit your user profile you won't see any information (there will tabbed headings but nothing appearing below them) either. It's possible that all of these problems are caused by your template. It's therefore likely that changing the template will resolve all of your Kunena problems.
The following user(s) said Thank You: Elnablo
15 years 9 months ago - 15 years 9 months ago #71528 by Elnablo
Hi sozzled,
I have absolutely no other problem within KUNENA except for the menus disappearing.
There is no missing BBcode toolbar, also the user profile works without a
problem.
The really strange thing is, that I can build a Forum where the buttons show at times
and disappear during the use of KUNENA. When I used the forum that was installed as
default, the menubuttons where right there nice and blue on top. They ALWAYS went bye
bye as soon as I clicked on a topic. Ooops, the buttons are GONE. Used the back-button
on the browser and there it was again, my blue menu!! Unfortuanately this is the only
way to move back up.
So my logic would be: If it works at some point, it should work everywhere.
I have tried 5 other templates, no change. I will try to set up a second forum om my site
to show you the effect.
Thanks for your help so far. I just can't believe, that KUNENA would react differently
at different points within KUNENA itself.
Time to create page: 0.286 seconds
