Sticky [Merged topic] How do I restore my Kunena menu?
15 years 10 months ago #82524 by xillibit
Yes, i have already said it there : www.kunena.org/forum/167-k-16-test-repor...search-on-page#82520
The topic has been locked.
15 years 10 months ago - 15 years 10 months ago #82539 by sorin21us
It's not Joomla 1.6. I used 1.5.
Now, please, can u tell me what's the problem?
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : ator-site | author: Web Design and Plus | version: 1.0.0 | creationdate: 12/2010
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Disabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Enabled (Version : 1.6.2) | My Kunena Forum Posts: Disabled or not installed
Last edit: 15 years 10 months ago by sorin21us.
15 years 10 months ago #82740 by johnmasterlee
Anyone else have this problem? It happened after I upgraded to the latest Kunena from the last version, but I'm not sure that was the cause.
Without it, I can't search, see latest posts, etc. I don't see any option to turn this on/off in configurations.
thekartel.com/forum/index.html
15 years 10 months ago - 15 years 10 months ago #82743 by sozzled
The problem really is that everyone has their own term for the the Joomla menu that's used in K 1.6 ... which is probably why you may not have found the solution when you searched the forum for an answer.
Here are a few terms that people have used:
Horizontal menu
Menu tabs
The menu at the top
Navigation tabs
Navigation menu
Top menu
The thing at the top of the page
and I'm sure that you can think of a few hundred other names that people have used. This probably explains why people have difficulty finding the answer.
The problem is really the same problem and I've have tried to collect as many of these different topics into this one topic to help others who find themselves in this predicament and they don't know what to search for. I hope that this topic will help sort out your "nav bar" problem. :)
Last edit: 15 years 10 months ago by sozzled.
15 years 9 months ago #84006 by Frankie4life
I cant set my kunenamenu to kuenamenu so all my links like Index, Recent Topics, New Topics, are missing from top of forum and I can only assign them to left or right column. What did I do wrong?
Thanks for our help.
15 years 9 months ago - 15 years 9 months ago #84007 by sozzled
It looks like, in addition to the many possible ways that other people have described this problem , we should add "Links at top are missing".
Frankie4life: I think you will find this topic will solve your problem.
Last edit: 15 years 9 months ago by sozzled.
Time to create page: 0.153 seconds
