Sticky [Merged topic] How do I restore my Kunena menu?
15 years 8 months ago - 15 years 8 months ago #90083 by sozzled
*** Topics merged ***
Please see the Create Menu feature; it's a little different if you are using J! 1.6.x.
@JustBe: Please remove the "sysplgaup_raffle" software (or disable it for pages that show Kunena content). This does not look to be compatible with Kunena.
The topic has been locked.
15 years 7 months ago - 15 years 7 months ago #90743 by andrewn51
My tabs were working fine, except that they weren't showing on all pages of the forum - for example, when reviewing a topic or a thread, the tabs were not showing.
I recreated the menu from the kunena control panel...now the tabs have disappeared entirely.
I have tried the solution of multiple deletes and recreates; I have tried using a menu alias to link to the kunena menu; tried a menu/kunena/entry page...
All kunena items are published.
So I'm now stumped and would appreciate any help or guidance to fix this.
The site is to be found here
The forum is for registered members login with barney/barney
Many thanks,
Andrew
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 256M
Joomla default template details : rt_panacea_j15 | author: RocketTheme, LLC | version: 1.5.5 | creationdate: November 15, 2010
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Last edit: 15 years 7 months ago by andrewn51.
15 years 7 months ago - 15 years 7 months ago #90763 by sozzled
andrewn51: See your PM. Can you enable your forum so that non-registered users have access to it, please?
Last edit: 15 years 7 months ago by sozzled.
15 years 7 months ago #90906 by sozzled
andrewn51's problem has been resolved. In his case we needed to create a new menu module using the Module Manager and assign it to the template position kunena_menu. After that, everything worked fine. Andrew also had a small Mootools issue involving the use of Rockettheme template (this was fixed by setting Build Titles Spans = Off in the RT template panel.
15 years 7 months ago #92780 by pickykim
Replied by pickykim on topic My Toolbar is MIA
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : newgreen6 | author: | version: 1.0 | creationdate: 2011-04-15
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.2.1) | UddeIm: Disabled or not installed
The default Kunena toolbar only shows up if it is on the forum entry page or one of the other pages that have tabs,i.e. index, recent topics, new topic, no replies, etc.
If you go into an actual forum topic, the toolbar disappears. Breadcrumbs don't work either. Help? Please?
15 years 7 months ago #92805 by pickykim
Replied by pickykim on topic Re: Ho enable tabs?
aka343 wrote: How enable those tabs? seartch prifile index no replies............
forum:
bf3.lt/index.php/forumas
How did you ever get this resolved? I am having the same problem. Any help would be great. Thx! Kim
Time to create page: 0.219 seconds
