Sticky [Merged topic] How do I restore my Kunena menu?
15 years 6 months ago - 15 years 6 months ago #94448 by sozzled
(1) Upgrade to K 1.6.4 (to make sure you upgrade your Blue Eagle template to K 1.6.4) and then
(2) use the "trash-burn-build" approach to restoring your Kunena menu. That should work for you. Let us know if you have problems.
Last edit: 15 years 6 months ago by sozzled.
The topic has been locked.
15 years 6 months ago #94451 by mstephan
I've tried the above steps about 5 times to no avail.
I noticed something on my last reinstall.
It said unable to write entry
and that the forum installed successfully at the same time ?
15 years 6 months ago #94455 by mstephan
Update: Okay so for some reason my templates still say they are version 1.6.3
Help?
15 years 6 months ago #94459 by sozzled
mstephan wrote: I noticed something on my last reinstall.
It said unable to write entry and that the forum installed successfully at the same time ?
Please read Securing Kunena . Make sure all your website files/folders are owned by Apache:Apache and that you have set the permissions according to the recommendations in the article I have referred you to. Then please reinstall Kunena.
15 years 6 months ago - 15 years 6 months ago #94934 by SpencerK
Hi all, firstly I would like to say this is a great extension - being able to integrate a forum into my site is going to help me sell goods, a lot.
I do have one issue though. When accessing the profile section, I cannot locate a link to take me back to the rest of the forum (please see attached image) - I have to click on a menu link Forum to go back. I'm not sure if this is a template issue, or an issue with the forum.
If this is a template issue, is there a way to add a link in the profile section to take me back to my topic selections.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
Joomla default template details : bulks_template_final02 | author: | version: 1.0 | creationdate: 2011-04-18
Third-party SEF components: sh404sef: Installed (Version : 2.2.5.964) | ARTIO JoomSEF: Disabled or not installed | AceSEF: Disabled or not installed
Last edit: 15 years 6 months ago by SpencerK.
15 years 6 months ago #95137 by JuggZaPoppiN
So I just recently installed Kunena, and I love the look and feel.
However, one thing I cant find an answer to is how do I get the tabs to show up on the top of the page.
Like the ones on this site. The Index, Recent Topics, New Topic, No Replies, My topics, Profile and search buttons.
Any help on this would be greatly appreciated.
Thank you.
Time to create page: 0.167 seconds
