Sticky [Merged topic] How do I restore my Kunena menu?
(1) In Extensions » Module Manager, make sure that you have not disabled or changed the module position of the "Kunena Menu" module (see image below):
(2) It depends on your site template, but (using Menu Manager) look at the menu item that points to your Kunena component. You should have something like this:
It is important that the menu type = alias. The parameters of this "forum link" should be like this:
There's a bit more to this, too, and it's all covered in excrutiatingly fine detail in the Wiki article Customised menus , but those are the two key ingredients that you need to have in place. If you don't have these things set up the way I've described then you have either changed something or your site template does not offer a place where the Kunena installer program could place a menu item for Kunena.
The solution is to either try the "trash-burn-build" approach (mentioned a dozen or more times on this site) to rebuild the standard Kunena menu "buttons" or, using your own skills in constructing Joomla websites, build the menu items again, from scratch. What seems rather apparent (from the number of messages posted on this forum) is that Joomla menu item construction seems to be a highly skilled art and may be difficult to teach in a self-help forum like this.
The "trash-burn-build" approach is simple:
(1) Find all menu items that relate to your forum.
(2) Trash all menu items that relate to your forum.
(3) Delete the menu kunena-menu from your site
(4) Empty the menu trash
(5) Use the Kunena control panel option Create Menu
... and that should be all that you have to do. Looking back over the number of times I've answered this question and the amount of time I've spent grabbing and editing screen shots (and the number of screen shots that I've posted here) I hope that, in future, people will read this topic and use the information we've written here. I most sincerely hope that what I've posted on this occasion helps.
Ultimately, if all of this is too difficult for people to do for themselves, there are many people who can perform this kind of service for a small fee, or course.
Hey everyone, I've been going through the same problem (Kunena menu disappears when you click a category or other link)
Forget mootools and all that junk. This is the solution. We are going to create our own menu, and scrap the buggy kunena menu.
1. Edit your templates index.php & add a module BEFORE the component. (Search for adding module positions in Joomla on Google) This involves adding code like
2. Add a Custom HTML module, and position it to the new position you created above. Add this to the HTML code
3. Then under Menu Assignment, make sure the menu is only viewed on the Forum page. If this doesn't work, uncheck ALL and try again.
4. Now still in your backend, go to Menus -> Kunena Menu. Check all menu items except the top one, Forum, and click the green tick to uncheck them all. You should now only have your top forum link, published.
5. Style it up with some css, I used
6. DONE!
I registered just to leave this comment for others experiencing the same problem with Joomla 1.6 & Kunena menus. I know how it sucks & nobody solved this to help. Hope this saves you much headaches. Good luck!
You are quite right. The menu has nothing to do with Mootools. It's a Joomla issue and I think your message may help a few people clear up their misunderstanding that the "missing" Kunena menu is, in fact, not really a problem with Kunena but with their understanding of how Joomla menus work.
Yes, it's possible to create a custom HTML module to fix these things. It's also possible to achieve a working result if people (a) use the Create Menu function in the Kunena control panel or (b) read Customised Menus in the Wiki.
Every little bit helps.
www.scumhunt.com
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : rhuk_milkyway | author: Andy Miller | version: 1.0.2 | creationdate: 11/20/06
board_title Scumhunt Forum Board board_offline 0 board_ofset 0 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 25 messages_per_page 20 messages_per_page_search 50 showhistory 1 historylimit 15 shownew 1 jmambot 0 disemoticons 1 template default showannouncement 0 avataroncat 1 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 0 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 0 allowfavorites 1 maxsubject 50 maxsig 1 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 0 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 350 allowfileupload 0 allowfileregupload 1 filetypes zip,txt,doc,gz,tgz filesize 240 showranking 1 rankimages 0 avatar_src fb_profile pm_component userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 0 userlist_username 1 userlist_posts 1 userlist_karma 0 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 0 userlist_userhits 1 latestcategory 0 showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 20 showpopsubjectstats 1 popsubjectcount 10 usernamechange 0 rules_infb 1 rules_cid 50 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 0 trimlongurls 1 trimlongurlsfront 20 trimlongurlsback 10 autoembedyoutube 1 autoembedebay 0 ebaylanguagecode en-us fbsessiontimeout 3600 highlightcode 0 rss_type topic rss_timelimit month rss_limit 20 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage categories default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 10 pollallowvoteone 1 pollenabled 1 poppollscount 10 showpoppollstats 1 polltimebtvotes 00:1:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 1 ordering_system replyid post_dateformat ago post_dateformat_hover ago hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png,image/psd imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access jomsocial integration_login jomsocial integration_avatar jomsocial integration_profile jomsocial integration_private jomsocial integration_activity jomsocial boxghostmessage 1 userdeletetmessage 0 latestcategory_in 1 topicicons 0 onlineusers 1 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 0 popthankscount 5 mod_see_deleted 1 bbcode_img_secure link listcat_show_moderators 0 lightbox 0 activity_limit 250 show_list_time 168 show_session_type 2 show_session_starttime 60 userlist_allowed 1 userlist_count_users 0 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1
Third-party components: Jomsocial 2.2.1
write a background color,
text.
Recommended hosting vps: VPS with a panel ispmanager lite (Promo Code:648215714)
