Sticky [Merged topic] How do I restore my Kunena menu?
15 years 10 months ago #81153 by Aventura
Cheers - cant believe I didnt see that. Unfortunatelty it doesnt appear to have worked. Im using Joomla 1.6 stable
The topic has been locked.
15 years 10 months ago #81156 by Mortti
In J! 1.6.0 is still some problems with K 1.6.2... next K 1.6.3 hopefully fix this
15 years 10 months ago #81159 by Aventura
Ok cheers, only reason im on 1.6 is because I couldnt get my standard site template to work again in 1.5.
Thanks again
Aventura
15 years 10 months ago - 15 years 10 months ago #81169 by Mortti
If you play with J! 1.5.22 and K 1.6.2 there should not be any problems with this.
Before you install Kunena 1.6 - check list
System Requirements
Installing or Upgrading Kunena
Did you test that blend option for your template?
Last edit: 15 years 10 months ago by Mortti.
15 years 10 months ago #81177 by Aventura
The site template wouldn't work properly, conflicted with mootools 1.2.4 - the kunena one was fine (using formality 1.6)
15 years 10 months ago #82024 by bzZ_
Replied by bzZ_ on topic navigation question
I dont know if this is the right section for this question, sry for that..
I installed the Aphotic II template to change the looks of the forum we use.
I recall the navigationbar being visible after I did so, but at this moment it is not.
Is there a setting to activate/deactivate this? Or is it a style issue in this case?
I mean this navigation bar:
thx!
