Question phpbb3 to Kunena
I found only another problem. In some of the post I'm importing there are some japanese message (written with kanji) and into Kunena I see only some "????" instead of kanji. I checked the tables charset and I found that kunena table have sweedish charset instead of unicode. I searched into the forum and I found some other people have the same problem but I didn't understand very well what is the way to fix it, I must to chaneg manually the charset associated to any table field manually or there is some other way to fix it?
Thank you again for the friendly support.
This would then be related to some other Kunena post that you'd have to create.
Glad that your migration worked anyway !
Unfortunately this last problem of japanese characters not imported well continue to be a seirous problem for me. I cheched the kunena/fireboard db tables, all the table have a charset set to sweedish, I changed manually all the attributes to unicode before import the data but after the import only some fields (like category name) has been imported correctly, all the other japanese words was showed as ????? into Kunena. Do you suggest to open a new discussion more specific to this problem?
