Question phpbb3 to Kunena
The old convertor.zip from phpbb3 to fireboard ran perfectly for me on a test server, update to Kunena 1.58 performed without a hitch and final act of migrating the smiles over worked as well.
Now just need those pesky passwords rehashed..
phpbb3passintegrator.zip doesn't work
Something though I do remember is that JFUSION does a password rehash on thier sync users.. Could this be used in any way to rehash (or could someone with great php knowledge than myself) perhaps do a bit of dissecting and get an idea or two on how to rehash the passwords???
Just a thought
:woohoo:
I didn't use that pass integrator... so I've no clue what it does. Anyway, the original converter (famous go.php) should do the trick itself.
Hi Kymmy,
Nope, looks like it just copied directly the password hash from phpbb, is there perhaps an updated version and I'm using an old version?
I did it! As my problem seemed to be some limitations from a free web host, I tried in my pc, installing XAMPP.
So now I've migrated phpBB to Kunena 1.5.8.
Now the thing is that the users can't login, it says that the username or password wrong. I've checked the users in backpanel, and it seems that they are all inactive. What can I do? Or could this be the passwords that were cleaned?
