Question phpbb3 to Kunena
17 years 1 month ago #31837 by Krycek
Replied by Krycek on topic Re:phpbb3 to Kunena
Yes, passwords should be copied from PHPBB to Joomla!. Here again a quick test should ensure that (with lambda member or made up member).
17 years 4 weeks ago #31966 by Matias
Replied by Matias on topic Re:phpbb3 to Kunena
phpBB3 encodes passwords in a different way, so they may work or not..
17 years 4 weeks ago - 17 years 4 weeks ago #32025 by Nebbers
Replied by Nebbers on topic Re:phpbb3 to Kunena
This thread has been very helpful with my quest to transfer a phpbb3 board to kunena! Thankyou to everyone who has input into the conversion
I have managed to sync all the userid between fb and phpbb. Posts display correctly etc but I am having difficulty logging in.
I have enabled the password plugin found on www.kunena.com/forum?func=view&catid=101&id=12556 and this too does not work.
Does anyone have any suggestions/fixes that may help?
I was thinking perhaps someone may have written a script that resets everyone's password and emails them the new one?
Last edit: 17 years 4 weeks ago by Nebbers.
17 years 4 weeks ago #32032 by Krycek
Maybe you should check on CB plugins side... there are some which make the users have to refresh ther password.
Glad for you that it worked !
16 years 11 months ago #35316 by Gleedo
Replied by Gleedo on topic Re:phpbb3 to Kunena
Hello all, very interested also in converting an existing forum to kunena.
I have vbulletin 3.84 which I can easily convert to phpbb3.06 and have just done that successfully as a test.
I think I read somewhere else in these forums that the next version of kunena will have built in converters for phpbb3. Is that correct? :blink:
I dont think I have enough techie experience to perform the detailed conversion instructions that others have tried to undertake :unsure:
16 years 10 months ago #35977 by Pescador
Replied by Pescador on topic Re:phpbb3 to Kunena
Hi all
I have a good phpBB3 Database backup (my server screwed things up), and now I want to build a Joomla 1.5 site with a forum.
After researching, I see that it's better to have a native joomla forum, than phpBB with a bridge or something like that, because I need things simple.
Npw I'm trying Kunena in a testing server, following the migration steps explained here , but when I try to open the converter in browser (In a browser, navigate to yoursite.com/converter/go.php.) it automatically goes to a error page. I've checked the servers MySQL info, and all seems ok. Could it be a server limitation?
If you want to try here's the link:
portalfpg.000space.com/converter/go.php
Any help?
