Question phpbb3 to Kunena
16 years 10 months ago #36388 by Krycek
Replied by Krycek on topic Re:phpbb3 to Kunena
Don't you have any test account to check by yourself ?
Then check wether accounts are enabled. If not, have a look to the DB and check for discrepancies with your account (that should work).
Last, you can still force new password registration for all accounts.
Even though, that is very strange...
16 years 10 months ago #36406 by Pescador
Replied by Pescador on topic Re:phpbb3 to Kunena
Hey
Sure I have some accounts for testings purpose, beside of my own. That's why I said that the users can't login. I'm still in development enviroment, not online.
I'll compare the tables from the database for this, and post the results here.
16 years 10 months ago #36419 by deminbo
Replied by deminbo on topic Re:phpbb3 to Kunena
very nice to read that there is going to be a converter from phpBB3 to Kunena! but where is link to the new migration script?
16 years 10 months ago #36647 by Pescador
Well, there is no new script. The one I used was this one.
It worked for me. The only problem I had was with the avatars and images, but that's explained in the guide, and some passwords doesn't work. Don't know why, but it's not bad since we can't reset the passwords if needed.
For my experience, use it in your pc (xampp, lampp, etc), then upload to the server once it's done...
Good luck with that
16 years 10 months ago #36653 by basnet
Replied by basnet on topic Re:phpbb3 to Kunena
phpbb is a huge huge software, to be able to convert from phpbb would be great.
16 years 9 months ago - 16 years 9 months ago #38632 by Kymmy
Replied by Kymmy on topic Re:phpbb3 to Kunena
I did find a way round the password issue. It's a long way round but it did work.
I first installed a test joomla with Jfusion linking into the phpbb3. Synced all the users using jfusion. Then on a fresh joomla install with kunena/fireboard (seperate DB from the test install I followed the go.php instructions in the phpbb3>>fireboard convertor. Once all the users/posts were transferred across I then used a simple php script to copy the passwords for each user from the jfusion/joomla DB to the relevant users in joomla/kunena DB (needed as the user ID's will not be the same.
The password copying script is available in this thread by the person who kindly made it for me
www.cableforum.co.uk/board/19/33659901-php-script.html
Yep it's a long way round but at least the jfusion usersync converts all of the passwords and as long as your secret key is the same in your joomla/jfusion and joomla/kunena installs the passwords will work.
Now what I would love is for the convertor to also copy across the users PM's
:kiss:
Last edit: 16 years 9 months ago by Kymmy.
