Question phpbb3 to Kunena
16 years 8 months ago - 16 years 8 months ago #41582 by zenith
Replied by zenith on topic Re:phpbb3 to Kunena
I have a problem... I have tranfared all topics post and etc... But there is no user. Here is screen for you. So what i did wrong?
I followed the tutorial with go.php file. So how i can import user with pw`s?
[img
Last edit: 16 years 8 months ago by zenith.
16 years 8 months ago #42025 by kubbah
Replied by kubbah on topic Re:phpbb3 to Kunena
Hi
I'm using this procedure to convert from phpbb3 to kunena (new install)
docs.kunena.com/index.php/PHPBB3_to_Kunena
when I run the .../converter/go.php
It stops here:
Importing data from phpBB
Connecting to Database... OK
Populating Categories...
Invalid query:
TRUNCATE TABLE `edi9048_2010`.`jos_fb_categories`
DELETE command denied to user 'edi9048_edile'@'localhost' for table 'jos_fb_categories'
any suggestion??
is there any better way to import users and post from phpbb3 to kunena?
thnx
16 years 7 months ago - 16 years 7 months ago #45966 by ron273
Replied by ron273 on topic Re: phpbb3 to Kunena
Hi there,
I tried to use the migration method from PHPBB3 to Kunena as written in the Kunena docs.
When I start the converter script(go.php) in step 7 it gives me the following output:
Importing data from phpBB Connecting to Database... OK Populating Categories... OK OK Populating Messages Table... OK Populating Messages_Text Table... Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 1873 bytes) in /home/xxxxxxxx/www/converter/go.php on line 316
When looking at the forum, it did migrate the categories and topics, but not the posts and corresponding users. Could this be because it is a fairly large database? (200 MB in total)
If so, is there a way around this? I already tried tweaking MAX_EXECUTION_TIME on my server, but that did not solve the problem.
Any help is greatly appreciated, as I desperately want to migration to a Joomla integrated forum solution.
Thanks!
Ronald
Last edit: 16 years 7 months ago by ron273.
16 years 7 months ago #45970 by Kymmy
Replied by Kymmy on topic Re: phpbb3 to Kunena
What's your memory limits on your PHP config?
16 years 7 months ago #45971 by Kymmy
Replied by Kymmy on topic Re:phpbb3 to Kunena
Looks like go.php errored out on the user import which it should do before the forums/posts
You can't correct the mistake without restarting again.. As far as passwords check a few pages back as the only way currently (scripted) is firstly to do a Jfusion install to create a joomla db with the users and backup that DB, do a Go.php to kunena on a fresh joomla install and then use the rehashed passwords in the jfusion joomla db using the script that was wrote for me by a friend
16 years 7 months ago #45972 by ron273
Kymmy,
Memory limit is currently 16M
Max execution time is 120
Cheers,
Ronald
