Question Joomla 6 support?
yeay.... github.com/Kunena/Kunena-Forum/pull/9924Ok, one thing that is already long time on my wish list is the Kunena Configuration.
This is implemented as a view (with model and controller), the reason is probably due to limitations in the past.
I would like to convert that to 'real' component options like every other component in Joomla has.
The functionality of how the config options will be used in the code will remain the same using the KunenaConfig class, so no changes needed there.
This would make the developers life a lot easier:
- new users expect configuration under options
- functionality is build upon core joomla default config.xml
- adding an option is as simple as adding a field, no more adding things in multiple places in the config MVC (and no more deprecated messages when missed a setting)
- a lot of code can then be removed, making maintenance easier
- etc.
Using JS we could even have the current functionality of highlighting fields whose value is not the same as the default value.
This is a lot of work, but doable before 7.0 release.
Is that something I can pursue or am I the only one who would like to have this / are there other reasons I do not know why we do not do it this way?
sharing = caring
- Thank you received: 2545
For my part, I would welcome these features, even though I don't run a forum myself (except on test sites).
Trying to give people an opportunity to connect here and give input that goes beyond my limited use case.
Also trying to avoid: "why didn't I now about this, now I have an issue" remarks
Anyway: good to have you onboard, I (and I'm sure I am not the only one) really value your testing efforts!
sharing = caring
They have released a version working on Joomla! 6.0 : www.joomlapolis.com/community-builder
I tested these Community Builder integration briefly and there don't seem to be any problems.1. Enable the Kunena CB integration plugin in System > Manage > Plugins
2. Verify the Kunena toolbar dropdown provides proper access to private messages
3. Verify the Kunena toolbar dropdown shows private message unread count
4. Verify the Kunena toolbar dropdown user preferences links to CB profile edit
5. Verify thread sidebar More button has icon to send PMS
I just noticed that if you enable the Debug System in the Global Configuration system tab,
the first time you log in via the front-end, you see a debug report that also displays your login name and password.
With kind regards
Leen
