Question Joomla 6 support?
1 year 4 months ago #233678 by ruud
Replied by ruud on topic Joomla 6 support?
Okay, started to rebuild to plg_system_kunena into a J5/6 new SubscriberInterface plugin.
I have the following questions:
  1. the onBeforeExtensionInstall and onBeforeExtensionUpdate are imo 'useless' as they only execute and stop the installation when somebody tries to install version 2.0.0 or below... Who would do that, that is like ancient version. So I would suggest to completely remove these triggered event methods, even if someone tries to install a version before 6.4 then these methods will NOT execute as in the constructor of the plugin this is disabled.
    If the check is still needed then IMO it should be in the installer script preventing these old versions from installing
  2. in the plugin there is a function: runJoomlaContentEvent but when searching the complete repository I cannot find anything that calls this function? So can this be removed?
  3. we need to discuss triggered events as these have changed in J4/5 and in J6 things will be removed as they where already deprecated some time ago (not in J6 alpha 6 they are not removed and Joomla core is also still useing triggered events). So remark below.
Triggered events:
search the code for 'triggerEvent' and you will fing Kunena 'events like onKunenaGetAccessControl, onKunenaBbcodeConstructs, etc.
These are currently implemented e.g. like this:         $classes = Factory::getApplication()->triggerEvent('onKunenaGetAccessControl');
but they should be implemented like:
$event = new KunenaGetAccesControllEvent('onKunenaGetAccessControl', []);
Factory::getApplication()->getDispatcher()->dispatch('onKunenaGetAccessControl', $event);
$classes = $event->getArgument('result');
in the example above I use KunenaGetAccesControllEvent, this is a choice as that then would be an event created for Kunena, this is something to discuss and decide if Kunena needs / wants its own events, or will workaround the (limited) Core provide Event that can be used for genereric use cases
sharing = caring
1 year 4 months ago #233679 by xillibit
Replied by xillibit on topic Joomla 6 support?
1°) The onExtensionBeforeUpdate is to prevent that people to try to downgrade by installing previous version, something need to be done on the install script to prevent that.
2°) I don't know what was the purpose of runJoomlaContentEvent, i have looked into kunena addons (discuss plugin...) but it's not used here neither so it can be removed.
3°) When the usages of triggerEvent will be removed the defintion class will disappear. The purpose of these events in Kunena was to be able to use it in plugins which can be provided separatly from Kunena. From my point of view these events should be keep.
1 year 4 months ago #233680 by ruud
ad. 1) The kunena install script extends the Joomla Core 'InstallerScript'. That has already the possibility to disallow downgrades:
[code]
     * Allow downgrades of your extension
     * Use at your own risk as if there is a change in functionality people may wish to downgrade.
     * @var    boolean
     * @since  3.6
    protected $allowDowngrades = false;
In the script you need to call the preflight function and if correct, then downgrading is not possible.
I will test this and if that works will remove the onExtensionBefore things from the plugin.
ad 2. I will remove runJoomlaContentEvent
ad. 3 we should refactor the way these events are called, in J5 / J6 these need to be refactored and use 'real' event classes' instead if the way you are doinging it now (using an eventTrigger and then pass an array with the data, which gives back the results (if any).
This needs to be discussed on impact as changing this and start using own Events has impact on 3rd party plugins that have no knowledge of these events. J5 had a B/C thing in place, but what I see in J6 this will be removed.
I'll do a setup for this for the onKunenaGetConfiguration events (also in the system plugin), so based on that we can see what the impact is and if that is a way forward.
Also something to think about.
Currently the system plugin also puts load on every (!) page visit where it does (or does not) cleanExpiredBans.
It would be 'better' to have a task plugin that does these chores on a timed interval (cron).
sharing = caring
1 year 4 months ago #233681 by ruud
Just to add. I think that onKunenaGetConfiguration can also be removed both from the plugin as well as from the KunenaConfig where it is triggered.
It is triggered in KunenaConfig, but nothing is done with the result of the triggered event:
        // Perform custom validation of config data before we let anybody access it.         $this->check();         $plugins = [];         Factory::getApplication()->triggerEvent('onKunenaGetConfiguration', ['kunena.configuration', &$plugins]);         $this->plugins = [];     }
So $plugins holds the parameters for the system plugin, but is not used . The function load() that triggers this event is void and does nothing with $plugins.
Correct?
sharing = caring
1 year 4 months ago #233683 by ruud
Just created a PR, we can discuss on Github :)
github.com/Kunena/Kunena-Forum/pull/9893
sharing = caring
1 year 2 months ago - 1 year 2 months ago #233934 by xillibit
With the beta3 planned as next release of Joomla ! 6.0 and the first RC in the corner and the creation of Joomla ! 6.1 branch it seems they want more stabilization. So i don’t know if they will continue in the 6.0 branch to remove the things set to be removed or they will continue in 6.1. After the release of the beta3 i don't think they will remove deprecated things. For now i think i will focus on new feature, check the changes in Joomla! 6.0 just in case they remove something.
I will check what remaining deprecated in K6.5 and set as deleted in Joomla! 6.0.
Last edit: 1 year 2 months ago by xillibit.
