Question Joomla 6 support?
1 year 2 months ago #233994 by rich
Replied by rich on topic Joomla 6 support?
If you want, you can send me one too. rich@*kunena.*org Apparently, I can no longer create this build with Apache ant.
1 year 2 months ago - 1 year 2 months ago #233996 by xillibit
Replied by xillibit on topic Joomla 6 support?
FYI : i have created a category for K7.0 :  www.kunena.org/forum/kunena-7-0-0-support
yes this can be archived
Good idea to do it if it can simplify the update process and others parts, it wasn't in the mind or forgotten
I will leave the archiving to you @xillibit as you probably have a folder or repository to move this to
As for the configuration: top! Will start working on this, this will take a little bit longer
I will take care of move the parts to archive
You aren't able to make a build for addons (discuss...) or for Kunena itself ?
Last edit: 1 year 2 months ago by xillibit.
1 year 2 months ago #233997 by ruud
Replied by ruud on topic Joomla 6 support?
And I think I did something wrong today. I can no longer insert attachments.
[b]Warning[/b]: Undefined variable $attachs in [b]C:\wamp64\www\joomla60beta4\components\com_kunena\template\aurelia\layouts\message\item\default.php[/b] on line [b]112[/b] [b]Rendering Error[/b] in layout [b]Message/Item[/b]: Kunena\Forum\Site\Layout\Message\MessageItem::canSeeAttachments(): Argument #1 ($attachments) must be of type Kunena\Forum\Libraries\Attachment\KunenaAttachment, array given, called in C:\wamp64\www\joomla60beta4\components\com_kunena\template\aurelia\layouts\message\item\default.php on line 112 in [b]C:\wamp64\www\joomla60beta4\components\com_kunena\template\aurelia\layouts\message\item\default.php[/b] on line 112 Layout was rendered in [b]C:\wamp64\www\joomla60beta4\components\com_kunena\template\aurelia\layouts\topic\item\message\default.php[/b] on line 34
I don't think I broke this with my recent changes. maybe @xillibit can have a look?
sharing = caring
1 year 2 months ago #233998 by rich
No, it's only at Kunena-discuss (build.xml:23: Unexpected attribute "description").
With other extensions it's no problem.
@ruud Thanks, I will test it.
1 year 2 months ago #233999 by rich
@ruud I installed Discuss on two Joomla 6.0.0-beta4-dev test sites with Kunena 7.0.0. It works without errors on both.
The following user(s) said Thank You: ruud
1 year 2 months ago #234000 by xillibit
I will take a look, i have moved the leen message here : www.kunena.org/forum/kunena-7-0-0-suppor...achment-issue#233995 to continue talk about this issue outside
