Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
Question Joomla 6 support?
8 months 1 week ago #233673
by ruud
Joomla itself has an installer script class that you can use (currently not able to check what the name / location is).
Or you can have a look at the installer helper I use in my extensions: it has all the methods I ever needed.
sharing = caring
Replied by ruud on topic Joomla 6 support?
That depends on what you need from the manifest.Hello,
For the install script by looking in the manual it's not the right way : manual.joomla.org/docs/next/building-ext...ion/install-process/
By using a clean sample like gived in the manual, i do'nt have a white page during the install. I need to reimplement of the features of the older script. How to get the manisfest data now ?
I have still whites pages on Kunena dashboard, categories manager...
I have created a 6.5 project on github repo, empty for now, do-you want an access to it ?
sharing = caring
8 months 1 week ago - 8 months 1 week ago #233674
by xillibit
Replied by xillibit on topic Joomla 6 support?
Yes the 6.5 branch exists : github.com/Kunena/Kunena-Forum/tree/K6.5 . Yes your PR about captcha was done against 6.5 branch : github.com/Kunena/Kunena-Forum/pull/9888
Ok i let you work on system plugin
The manual say the script needs to use libraries/src/Installer/InstallerScriptInterface.php actually the class acutally in script extends InstallerScript or the other method is to use a Dependency Injection Container
P.S. : i have just seen that i forgot to copy some lines which defines the versions allowed, now the check of requirements works
It's to just retrieve the version of Kunena to be installed for the requirements checksThat depends on what you need from the manifest.
Last edit: 8 months 1 week ago by xillibit.
8 months 6 days ago #233678
by ruud
sharing = caring
Okay, started to rebuild to plg_system_kunena into a J5/6 new SubscriberInterface plugin.
I have the following questions:
search the code for 'triggerEvent' and you will fing Kunena 'events like onKunenaGetAccessControl, onKunenaBbcodeConstructs, etc.
These are currently implemented e.g. like this: $classes = Factory::getApplication()->triggerEvent('onKunenaGetAccessControl');
but they should be implemented like:
$event = new KunenaGetAccesControllEvent('onKunenaGetAccessControl', []);
Factory::getApplication()->getDispatcher()->dispatch('onKunenaGetAccessControl', $event);
$classes = $event->getArgument('result');
in the example above I use KunenaGetAccesControllEvent, this is a choice as that then would be an event created for Kunena, this is something to discuss and decide if Kunena needs / wants its own events, or will workaround the (limited) Core provide Event that can be used for genereric use cases
- the onBeforeExtensionInstall and onBeforeExtensionUpdate are imo 'useless' as they only execute and stop the installation when somebody tries to install version 2.0.0 or below... Who would do that, that is like ancient version. So I would suggest to completely remove these triggered event methods, even if someone tries to install a version before 6.4 then these methods will NOT execute as in the constructor of the plugin this is disabled.
If the check is still needed then IMO it should be in the installer script preventing these old versions from installing - in the plugin there is a function: runJoomlaContentEvent but when searching the complete repository I cannot find anything that calls this function? So can this be removed?
- we need to discuss triggered events as these have changed in J4/5 and in J6 things will be removed as they where already deprecated some time ago (not in J6 alpha 6 they are not removed and Joomla core is also still useing triggered events). So remark below.
sharing = caring
8 months 6 days ago #233679
by xillibit
1°) The onExtensionBeforeUpdate is to prevent that people to try to downgrade by installing previous version, something need to be done on the install script to prevent that.
2°) I don't know what was the purpose of runJoomlaContentEvent, i have looked into kunena addons (discuss plugin...) but it's not used here neither so it can be removed.
3°) When the usages of triggerEvent will be removed the defintion class will disappear. The purpose of these events in Kunena was to be able to use it in plugins which can be provided separatly from Kunena. From my point of view these events should be keep.
8 months 6 days ago #233680
by ruud
[code]
* Allow downgrades of your extension
* Use at your own risk as if there is a change in functionality people may wish to downgrade.
* @var boolean
* @since 3.6
protected $allowDowngrades = false;
In the script you need to call the preflight function and if correct, then downgrading is not possible.
I will test this and if that works will remove the onExtensionBefore things from the plugin.
ad 2. I will remove runJoomlaContentEvent
ad. 3 we should refactor the way these events are called, in J5 / J6 these need to be refactored and use 'real' event classes' instead if the way you are doinging it now (using an eventTrigger and then pass an array with the data, which gives back the results (if any).
This needs to be discussed on impact as changing this and start using own Events has impact on 3rd party plugins that have no knowledge of these events. J5 had a B/C thing in place, but what I see in J6 this will be removed.
I'll do a setup for this for the onKunenaGetConfiguration events (also in the system plugin), so based on that we can see what the impact is and if that is a way forward.
Also something to think about.
Currently the system plugin also puts load on every (!) page visit where it does (or does not) cleanExpiredBans.
It would be 'better' to have a task plugin that does these chores on a timed interval (cron).
sharing = caring
ad. 1) The kunena install script extends the Joomla Core 'InstallerScript'. That has already the possibility to disallow downgrades:Hello,
[code]
* @var boolean
* @since 3.6
sharing = caring
8 months 6 days ago #233681
by ruud
sharing = caring
Just to add. I think that onKunenaGetConfiguration can also be removed both from the plugin as well as from the KunenaConfig where it is triggered.
It is triggered in KunenaConfig, but nothing is done with the result of the triggered event:
So $plugins holds the parameters for the system plugin, but is not used . The function load() that triggers this event is void and does nothing with $plugins.
Correct?
// Perform custom validation of config data before we let anybody access it.
$this->check();
$plugins = [];
Factory::getApplication()->triggerEvent('onKunenaGetConfiguration', ['kunena.configuration', &$plugins]);
$this->plugins = [];
Correct?
sharing = caring
Time to create page: 0.292 seconds
