- Thank you received: 3
Solved K 2.0.2, K 2.0.3: problems with preview
- roland_d_alsace
- Junior Member
After upgrade from k2.0.1 to k2.0.2 the preview option before submit a post dont display nothing (preview field leave blank).
Have you an idéa ?
Regards.
- Thank you received: 191
- roland_d_alsace
- Junior Member
With firebug :
JSON.parse: unexpected character
Line 503
After upgrade from 2.0.1 to 2.0.2 The Prewiew button does not work for all users. How I can fix it? Im using Kunena 2.0.2
Are-you using default template for Kunena and Joomla! ?
Can-you give me your site url with a test account ?
