Sticky Before you post your question, read this first
- Limbless_One
I have installed kunena 2.0.3 forum into a fresh joomla 2.5.8 installation and everything is going smoothly so far except i cant edit my profile or ad a signature or avatar.
tried following the help links above to hopefully find the answer there , but kept getting errors on you're links.
joomla theme i am using is rockettheme / quasar. web site : limbless-one.com
- 9themestore
- Premium Member
I think, there are two reason to make your problem.
1. Conflict js with js of the template.
2. Js in the kunena template not latest version.
You try to use joomla default template to check problem.
Regards
1. In your Joomla Template configuration search for option "Build Titles Spans" and disable it
2. If you want to use Kunena Avatars you need to disable "Gravatar Integration" kunena plugin
Hope this helps
Limbless_One: as you will see, by looking at a few of the messages posted in this topic, your issue is not isolated to K 2.0.3. Your problem is caused by a Javascript library, loaded by another extension that you have installed on your website, that conflicts with the Joomla Mootools Javascript library that is required for Kunena to work.
TKtemp has provided you with the most likely solution to your problem. For anyone else reading this topic who has a similar problem, please see the solutions recommended in msg #1 of this topic.
- Limbless_One
Query: INSERT INTO `user` (user_id,user_name,user_password,user_newpassword,user_newpass_time,user_email,user_email_authenticated,user_real_name,user_token,user_registration,user_editcount) VALUES (NULL,'Limbless_One','','',NULL,'',NULL,'','','20130110005317','0')
Function: User::addToDatabase
Error: 1062 Duplicate entry 'Limbless_One' for key 'user_name' (localhost)"
so i find it hard to find the answer , sick of the circle work
- Limbless_One
