Sticky Before you post your question, read this first
Please read msg #1 in this topic. You have a Javascript library conflict within Joomla that you need to fix.
And within an `t want natyi paragraph.
You have something in your site that is changing the way that Javascript handles the image lightbox; I do not know, specifically, what that "something" is. The "something" is another piece of Javascript; another Javascript library. Your website loads over 12 Javascript libraries. A "typical" J! 2.5 website (using the Beez 20 template) loads 5 Javascript libraries. Kunena loads another 2 Your problem is caused by the one or more of the 5 more that are loaded by other Joomla extensions you are using; one of these is interfering with the operation of the library ../media/kunena/js/mediaboxAdv-min.js.
../media/kunena/js/mediaboxAdv-min.js is responsible for the image lightbox. You need to make sure that nothing else interferes with it.
It may also help to read [Help] Kunena 2.0.2 VS Chrome & Explorer
I am in the code do not see XTM run the library
contains only such
The most weirdest part is that it works perfectly on another site with thesame settings.
When I want to upload an avatar I go to my profile and when I want to click on 'Browse..' it doesnt do anything, you can click a thousand times on it and it goes nowere.
I've looked around for the solution about the processing but just nothing.
Installed version: 2.0.3
Sounds like a Javascript-related issue to me.
