Sticky Before you post your question, read this first
13 years 11 months ago - 13 years 11 months ago #138048 by inbal
update:
I now see that when I change the template to "Blue Eagle Right-to-Left (default-rtl)" the css is really weied and messed-up but the add file works.
the other 3 templates are pretty much the same but the add file does not work...
Last edit: 13 years 11 months ago by inbal.
13 years 11 months ago #138050 by inbal
I found the problem but I don't know how to fix it:
In the template where the button works, (but the css is really really off) there are 2 buttons
there is "add file" and "insert"
in the template whrere the design is good, there is only 1 button. the "insert".
and because I don't have a button to add files first, the "insert" alone would not do.
attached a print screen of them both:
13 years 11 months ago #138059 by alexspain
Hi all,
i ve got a virtuemart shop running with mynxx template from rockettheme and added the kunena forum to it.
Everything is working fine except that a user cant edit his profile.
You can click on PROFILE -> EDIT, but then you cant edit anything.
Any ideas?
Kunena 1.7.2
www.nikkisnylonsshop.com
13 years 11 months ago #138063 by sozzled
*** topics merged ***
Please read msg #1 in this topic.
13 years 10 months ago #138448 by noonakab
(joomla 1.6.25 + kunena 2.0)
edit profile button not able clck
13 years 10 months ago #138450 by sozzled
Please read msg #1 in this topic. J! 1.6.5 is not supported by Joomla and is not recommended or suitable for K 2.0.
Time to create page: 0.160 seconds
