Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
I delete kunena item in main menu, delete Kunena menu. Update to 1.6.1 DEV. Set kunena item in main menu as default. Have error 404 in main page. Then I change kunena item in main menu to show Entrypage. Error 404 is go away and Kunena menu is showed. But when i go to any topic, or any other forum page, Kunena menu not showed.
P.S. sorry for my english
It's not public yet -- we need to make sure that it works and we have some other issues that we need to fix first as well.
Please enable debug mode form Kunena and look if you get any notifications/information that may help you to find the issue.
Your problem sounds like you have issues with your menu, not Kunena itself. Did you change menu item in your main menu to be Entry Page as I told in few messages back?
- Oscarfishlover
- Premium Member
Matias wrote:
If you are still having troubles with menu, you should go to your main menu and find your forum item from it. Then change menu type to Kunena: Entry Page and point Default Menu Item to Kunena Menu >> Forum. This will act just like menu alias, except that main menu highlighting is gone (will look into it later). Some menus may get highlight back if you have excactly the same URL/alias for both items.
E.
Okay, to a certain extent, these instructions worked and at least now when I arrive at the forum, I am seeing the forum menu. Unfortunately my excitement was short lived as when I click on a topic such as "welcome to kunena" yet again I am seeing a caution message at the top of the page "kunena menu is messing: no navigation was found..... Well you know the rest.
Also, the forum menu has disappeared again.
We're getting there, but there's no way I am updating my Oscar fish website until I know everything works properly.
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
- freedomcoach
- Premium Member
- Thank you received: 3
I installed K1.6 on my test site. It seems to be working fine. However, I'm seeing one error message at the top of my forum saying "Kunena Notice: Menu item /discussion-forum (Itemid=55) does not have Kunena Menu.". I checked the menu item and do not see anything wrong with it. Any suggestions?
Sincerely,
Howard
