- Thank you received: 2
Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 11 months ago #64061
by NoMAD
Replied by NoMAD on topic Re: upgraded k 1.6 stable -> problem with the menù
@Matias:
Joomla 1.5.20 + JA-Purity II + Joomla core SEF + Kunena 1.6.1 => problems with menu solved, activated debug, no other messages or Kunena Notices.
THANKS!
THANKS!
- marcusfive
- Junior Member
15 years 11 months ago #64066
by marcusfive
Replied by marcusfive on topic Re: upgraded k 1.6 stable -> problem with the menù
@Matias:
Thank you!
Now it work!
Joomla 1.5.20 + celebs_plaza + Joomla core SEF + Kunena 1.6.1.
i have sh404, but i have set to not edit sef_exit of kunena, so in this way i think that work only joomla core sef for kunena, if i don't do, there are an error and don't open page of forum.
But why now is all in english? is possible have kunena 1.6.1 also in italian?
i can use this version? or is better if i wait stable version of kunena 1.6.1?
Thank you very much for help!
Thank you!
Now it work!
15 years 11 months ago #64069
by Matias
Replied by Matias on topic Re: upgraded k 1.6 stable -> problem with the menù
Good that this worked for you two! It was really hard to find solution that worked in every case I tried.
@ marcusfive:
Italian is missing translations from backend. You can still translate menu items by hand -- just rename items in Kunena Menu as you wish..
@ marcusfive:
15 years 11 months ago #64074
by Matias
Replied by Matias on topic Re: kunena Menu problem
Good. Now just follow instructions in this topic:
www.kunena.com/forum/168-k-16-support/63...it=10&start=20#64053
15 years 11 months ago #64096
by vietphi
Replied by vietphi on topic Re: upgraded k 1.6 stable -> problem with the menù
where i can find kunena 1.6.1 ?
I had the same problem with this, even this is the first time i installed kunena forum.
I try all the troubleshoot of wiki and @matias but nothing solved. Hope kunena 1.6.1 will be better.
Sorry, my bad in english.
- fullstackedpoker
- Junior Member
15 years 11 months ago #64099
by fullstackedpoker
Replied by fullstackedpoker on topic Re: upgraded k 1.6 stable -> problem with the menù
I need 1.6.1 also, would it have been that hard to post it publicly and a link to it?
Thank you for working it out though. I look forward to the solution.
