Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
16 years 1 day ago - 15 years 11 months ago #63751 by zaitx
Kunena menu disapper in forums and sometimes i have error like that
Kunena Notice: Menu item /forum (Itemid=132) does not have Kunena Menu.
Kunena menu works only in category page.
check it out www.enas.com.pl
Last edit: 15 years 11 months ago by sozzled. Reason: Merged topic
16 years 1 day ago - 16 years 1 day ago #63755 by NoMAD
Same problem here, this new router is useless (adding problems to a simple problem). Kunena RC1,2,3 did not have this problem.
No matter what I do, all looks ok for non-registered users but when registered users see:
Mainmenu(joomla) - Forum www.blabla.com/component/kunena/?view=entrypage&defaultmenu=302
with Kunena Kunena Notice: No menu item assigned. Redirected to /forum (Itemid=302)
Ok, but once in forum that "Forum" link from Mainmenu will transform into www.blabla.com/forum/entrypage
And of course we have Kunena Menu Index that will go as i wish in forum main/home page but the link there is www.blabla.com/forum/index
Tried all from that sticky post.. nothing works as expected. Sure, if Kunena routes all via that new internal router.. c'mon!!! more than one year and we face this kinda problems all in the name of what?
We just need a simple, fast and easy way to put a SIMPLE link in our Joomla Mainmenu, link that will take us to our beloved Kunena Forum Main Page. From that.. Kunena Menu can show as many tabs as users want, without messing up with other menu item.
We shall all try to learn joomla and kunena menu systems over and over again?
PS1 - Sorry to all Kunena dev but its frustrating to stumble upon simple things.
PS2 - Keep it simple guys.
Last edit: 16 years 1 day ago by NoMAD.
The following user(s) said Thank You: srisiam2527
16 years 1 day ago - 16 years 1 day ago #63757 by Matias
@ marcusfive:
First two should work, but only if your menu module supports aliases (Joomla does support, other menus can have bugs, please contact author to fix those).
Last one doesn't work as you cannot have two menu items with the same alias.
Workaround: Create menu item of type: Kunena Forum: Entry Page and point it to Kunena Menu >> Forum. It will work, but it doesn't highlight the menu.
Another way is to copy the whole Kunena Menu into your main menu and use it.
Last edit: 16 years 1 day ago by Matias.
16 years 1 day ago #63765 by Matias
@ NoMAD:
Something is seriously wrong in your site. You seem to use SEF, but URL from the menu is wrong. Those URLs are generated by menu module and your SEF component. Either of them has a serious bug in it or SEF doesn't support Kunena 1.6. I suspect that it's your SEF component (you're not using Joomla SEF..?).
Upgrade SEF to the latest and if the issue persists, tell us what it is so we can fix it.
PS. only Admin will see that error message. Other users get silently redirected to the right URL.
16 years 1 day ago #63776 by zaitx
I have same problem,
I copy all menu to main menu on normal users its working but
On admin i see error like this:
Kunena Notice: You do not have default Kunena Menu.
When i go as a guest ther isn't any menu.
When i dont copy it and set only forum link in main menu it is a conflict with forum alias.
Wher is simple HOW TO add menu?
16 years 1 day ago - 16 years 1 day ago #63778 by Matias
Replied by Matias on topic Re: kunena Menu problem
Please look at sticky (yellow) topics in support forum.
