- Thank you received: 2
Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 11 months ago #63906
by NoMAD
Replied by NoMAD on topic Re: upgraded k 1.6 stable -> problem with the menù
@SMurflalus:
Just install 1.5.9 and choose downgrade when new installing/upgrade panel from Kunena will ask (thats a feature that had improved a lot).
On the other hand since we've been told that this new "kunena menu" is or will be very powerfull I must also say that "power is nothing without control".
- SMurflalus
15 years 11 months ago #63979
by SMurflalus
Replied by SMurflalus on topic Re: upgraded k 1.6 stable -> problem with the menù
Thx NoMAD.
I got Kunena 15.12 again and all works ok.
As usually "stable" doesn't mean "well workin'", so never be in a hurry with upgradin' if it isn't necessary ( like security). I'll stay few next months with 1.5.12. it's enough for me.
15 years 11 months ago #64016
by dannydekr
Replied by dannydekr on topic Re: upgraded k 1.6 stable -> problem with the menù
Don't know what you guys did, but I use my forum as homepage. In RC3 it worked perfect, now the Kunena menu is gone when someone uses the main-URL, and when I try to use the 'create menu' stuff to fix it, I get a 404 - no component found error when I go to my main URL..
Couldn't find out what the problem was, and I din't want to use .htaccess to route the main URL to /forum/index to show the Kunena menu, so I restored my backup and will use RC3 for a while..
Sorry, love the forum component and appericiate the hard work. But in my opionion you shouldn't do these major changes when you're already in RC3 phase..
15 years 11 months ago #64023
by Matias
Replied by Matias on topic Re: kunena Menu problem
Both of you: check your PM and report back to me if the issue has been fixed.
15 years 11 months ago - 15 years 11 months ago #64053
by Matias
Replied by Matias on topic Re: upgraded k 1.6 stable -> problem with the menù
Everyone (I hope I got you all), please check your PM.
I've used last two days trying to find all potential issues and make a simple way to fix everything I found (thank you from pointing me the issues). There's a new build in your PM, which contains only changes that are trying to put most menu issues into history (I hope). If not, I need to think again how to solve them.
Anyway, I got everything to work in my site (except menu highlight in some cases) -- also in templates and menus that do not support aliases. I'm sure that I still missed something, but its where you come into the picture.
When you install new daily build (Kunena 1.6.1-DEV), all notification messages should go away -- until you enable debug mode in Kunena (first tab in configuration). Debug mode will still show you messages from the potential issues, but most of them are just telling what Kunena detected and how it tried to fix the issue.
If you are still having troubles with menu, you should go to your main menu and find your forum item from it. Then change menu type to Kunena: Entry Page and point Default Menu Item to Kunena Menu >> Forum. This will act just like menu alias, except that main menu highlighting is gone (will look into it later). Some menus may get highlight back if you have excactly the same URL/alias for both items.
I'm waiting for your replies. If you still keep having these issues, please send us user/pw for temporal administrator account, so that we can check your site. If you put them into forum, please use
Last edit: 15 years 11 months ago by Matias.
- Oscarfishlover
- Premium Member
15 years 11 months ago #64056
by Oscarfishlover
The #1 Oscar Fish website on the net
Joomla! 2.5.14
Kunena 3.0.2
Replied by Oscarfishlover on topic Re: kunena Menu problem
okay, followed your instructions. I hope you meant"enable debug mode" in configuration?
Anyway, this is what the forum looks like now
www.g0vqy.co.uk/forum
Joomla! 2.5.14
Kunena 3.0.2
