Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 11 months ago - 15 years 11 months ago #63703 by marcusfive
i have now upgarded my kunena to the stable version.
But now there are this error message in frontend of kunena:
Kunena Notice: Menu item /kunena (Itemid=127) does not have Kunena Menu.
i have also try to unistall component and reinstall but it is the same.
How can i solve?
and congratulation for the stable version!
Thank you.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 32M
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.2.3) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
Last edit: 15 years 11 months ago by sozzled. Reason: Merged topic; changed subject to improve search relevance
15 years 11 months ago #63709 by Matias
No need to uninstall.
Kunena just detected issue in your Joomla menu, which prevents it from showing Kunena Menu (Index, Recent Messages...). Detection was added to the stable as many people have been complaining of missing menus.
Please check this: Troubleshooting Kunena Menu
15 years 11 months ago #63715 by marcusfive
in the menulink i have set: index
but the link generated are: index.php?Itemid=151
and this is link to the last article of my site and not to the forum.
how can solve?
Thank you
15 years 11 months ago #63722 by Matias
Use menu link instead. See sticky topic that I just added.
15 years 11 months ago #63734 by Kube
Go to Kunena Control Panel, and use "Create Menu" function, this tool will create the correct forum link in the main menu ;)
Regards.
15 years 11 months ago - 15 years 11 months ago #63738 by marcusfive
i have do, it create the forum link, but the link are:
/index.php?Itemid=160
and is not the corret link.
and if i go: menù joomla->new->alias->menù voice=kunena menù index
it is the same.
if go: joomla->new->Kunena Forum: Category Index
the url are: index.php?option=com_kunena&view=listcat&catid=0
but the broswor said that the server is redirect the application for this page so that can never be completed.
i seen the the topic just added by matias and also the wiki, but i have not succeeded in resolving
thank you
Last edit: 15 years 11 months ago by marcusfive.
Time to create page: 0.299 seconds
