15 years 8 months ago - 15 years 8 months ago #89265 by sozzled
See PM
EDIT: Problem solved. User disabled GTranslate module and Kunena then worked.
15 years 8 months ago - 15 years 8 months ago #89487 by gvvampire
Replied by gvvampire on topic Profile edit problem
Hi there,
Iam using the latest forum but when i try to edit the profile i take the following picture.
There is nothing to edit...!!!
I have also enable the moo plugin and i am using the 1.5.22 joomla.
Could you please inform me what must i do?
Thank you for your time.
Last edit: 15 years 8 months ago by gvvampire.
15 years 8 months ago - 15 years 8 months ago #89492 by pedrox
Kunena 1.6
Not show the options for editing ...
Last edit: 15 years 8 months ago by pedrox.
15 years 8 months ago - 15 years 8 months ago #89512 by sozzled
gvvampire and pedrox: Please see msg #1 in this topic.
The following user(s) said Thank You: pedrox
15 years 8 months ago #89633 by wabrix
Hello!
I'm runnin K 1.6.3 on J!1.6.1
At some point toolbar has gone broken(attacked image showing the issue) and smilies have stoped working, they(smilies) do appear, but are not clickable.
Unfortunately i noticed this issue only now and can't track if this apeared after adding some new modules to the site.
Have tried switching/reseting templates and settings of the site and Kunena to state there was no issue, but no luck up till now :(
tested on FF,Chrome,IE8/9,Opera
my config report on next post below
15 years 8 months ago #89634 by wabrix
my config report:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 96M | Max file upload: 24M
Joomla default template details : beez_20 | author: Angie Radtke | version: 1.6.0 | creationdate: 25 November 2009
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: The file doesn't exist comprofilej.xml ! | Jomsocial: Disabled or not installed | UddeIm: The file doesn't exist uddeim.j15.xml !
Time to create page: 0.164 seconds
