15 years 8 months ago #88223 by fraxxit
15 years 8 months ago #88266 by xpatman
I have just upgraded from kunena_v1.5.14 to kunena_v1.6.3 and in short I wish I left it alone
I am using Version 1.5.22 and the latest YouEvents Template but this Mootools 1.2.4 has really messed up my site with two of my main modules unable to run
I can not make head or tail of the settings
I have been using a JavaScript Control with Mootools.js and Caption.js options but none made any diffidence, if I turn the Mootools off I get a kunena error - Kunena: You have a plug-in that uses MooTools 1.1 or a custom version of JHTMLBehavior. Many features, including Quick Reply and the BBCode editor, may be broken. Please enable the System - MooTools Upgrade plug-in.
and with it on I have screwed up modules WHY should this happen ???
Modules with errors are- Listbingo = mod_lbads and K2 Content Slider - mod_lofk2slideshow
15 years 8 months ago - 15 years 8 months ago #88268 by sozzled
Please read msg #1 in this topic. Thank you.
15 years 8 months ago - 15 years 8 months ago #88286 by xpatman
I have tried to read and understand =
1. Common causes of Mootools (Javascript library) issues and Kunena; and
2. Javascript and Kunena
But wow
is there any chance of getting a two line answer or a plug-in to the question
15 years 8 months ago - 15 years 8 months ago #88290 by sozzled
I already gave you a one-line answer before. :)
Maybe I should add that it's quite feasible to fix the other problems that you are having but, not necessarily, as quickly as you might like them fixed. The articles should provide all the answers that you need - and you have already discovered the causes of the problems yourself - but it's up to you to steadily work through the issues. As you have already discovered, the cause of the problems is not Kunena.
15 years 8 months ago - 15 years 8 months ago #88326 by GoremanX
For the record, the Mootools upgrade plugin has been present in Joomla for over a year. If people are still using extensions that don't support it or work around it, you need to take it up with the people who maintain these broken extensions. Kunena itself isn't broken in this regard, it's just more up to date than the extensions you're using.
Bottom line: Mootools upgrade needs to be enabled for Kunena 1.6 to work. If Mootools upgrade breaks something else on your site, you need to fix that something else.
www.friendlyphotozone.com
Last edit: 15 years 8 months ago by GoremanX.
Time to create page: 0.160 seconds
