15 years 8 months ago - 15 years 8 months ago #89642 by sozzled
G'day, wabrix, and welcome to Kunena.
Please read msg #1 in this topic. Thank you.
15 years 8 months ago #89647 by wabrix
thnx, that fixed it
cheers
15 years 8 months ago #89888 by justmebg
I am having the same issue - no attach file window opens, global Joomla settings do not repress attachments. This is important for my forums as I am using them for support (much like this one) I've tried both a custom 1.6 template and the default - doesn't change anything.
Joomla default template details : impacto | author: Casey Lee | version: 1.8 | creationdate: 09/16/10
Kunena default template details : Adrine - Kunena 1.6 Template | author: TemplateKunena Team | version: 1.6.2 | creationdate: 2011-01-25
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Installed (Version : 2.2)
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Enabled (Version : 1.6.2) | Kunena Search: Enabled (Version : 1.6.2) | My Kunena Forum Menu: Disabled or not installed | My Kunena Forum Posts: Disabled or not installed
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Disabled or not installed | Kunena Login: Enabled (Version : 1.6.2)
15 years 8 months ago #89889 by sozzled
justmebg: which of these issues are you having difficulty with that seems to be the one that you are using this topic for:
  1. No Attachment Browser
  2. No Local Photo upload
  3. Insert Video URL not working
In what way(s) are you having a problem?
To clarify your question further, are you not getting the "file open" dialog appearing when you click the Browse button when you try to upload an attachment or a photo (image)?
The insert video issue is unrelated to these other things, I think.
Further, I recommend that you read how to properly setup Joomla SEO .
I would also recommend that you disable "integration activity" unless you have a specific need for this feature.
The following user(s) said Thank You: justmebg
15 years 8 months ago #90182 by Gatekeeper
Replied by Gatekeeper on topic a few problems
1.
Ive just installed kenuna 1.6.3 forum on our 1.5 joomla website, its great BUT a few issues
Firstly the "mootools upgrade plugin" stopped the "a menu item working that used javascript" this particular component had to be un installed which was a shame as it was a major part of our site , but before I uninstalled I disabled the mootools upgrade plugin and it worked again
So I had to choose between having the new forums with the upgrade plugin for mootools or loosing the component our site used
2.
We have no editor on our forums, we have smilies but they only work by placing the code in the post
everything else is fine
Just wondered if anyone could help thanks
15 years 8 months ago #90212 by sozzled
G'day, Gatekeeper, and welcome to Kunena.
Time to create page: 0.169 seconds
