- Gatekeeper
- Junior Member
I read it , and applied some changes and it works now, thanks
Seems just putting the new mootools plugin first made it work
thanks gb
- da21f8a1397f7a5fc3ca78b7
- Banned
This message contains confidential informationhtaccess: Exists | PHP environment: Max execution time: 10 seconds | Max execution memory: 24M | Max file upload: 1500K
Joomla default template details : blueish | author: Juergen Koller | version: 1.0 | creationdate: 04.12.2010
Ran into trouble when tried to use Kunena with a nice template I have found: BLUEish. There's no trouble regarding forum layout, colors ans so on.Modules: Kunena Latest: Disabled or not installed | Kunena Stats: Disabled or not installed | Kunena Login: Disabled or not installed
The trouble is when I try to edit my profile, clicking the "Save" button gives no effect. "Cancel" works right (or how is that button called, sorry, using russian translation... A button to cancel profile change).
Changing template helps! So the trouble should be in template itself, but... Where could it be?
I had this trouble on a test installation of Joomla. Got tired of all that stuff, purged my DBs and filesystem and installed fresh Joomla, BLUEish and Kunena back. Exactly the same...
Using Joomla 1.5, if anyone interested.
When you are using bluefish template, do you see bbcode toolbar ?
If, you don't see it you have an issue with Mootools library
- Banned
Mootools are mentioned in template's settings, and I have them turned on.
Anyway, BB-code panel shows up and works perfectly, at least when inserting bold text...
G'day, D-side and tbird412, and welcome to Kunena.
Please read msg #1 in this topic. Thank you.
