15 years 8 months ago #88731 by deroderuiter
Replied by deroderuiter on topic Re: Avatars
Thank you very much! Mootools was not activated in my template. After activating everything is ok now!
15 years 8 months ago #88755 by sozzled
Please read msg #1 in this topic. Thank you.
15 years 8 months ago - 15 years 8 months ago #88960 by eycel
I have a disapearing edit button in profile. The button works alright if you click it fast enough but it disapears after so long. I read through the thread "kunena problems with javascrip 93 page thread" but I didnt find any solution and thought maybee someone has one for me.
At first nothing in profile worked, then I turned n mootools in joomla and the basic stuff in profile worked but the edit button disapeers. I have tested on multiple webhosts and it happens on both. I should mention I'm using a rockettheme template zephyr. You can see for your self if you register on my website and try to use the profile, my site is www.crysis2leaked.com . Thanks for any help.
To be more specific, when you hit profile, the normal working page comes up, then a second later it flickers and then the edit disapears and the "Profile for name (name)" turns into "Profile for name (name) Edit" which the edit turns into part of the name and isnt clickable.
Here is my report configuration settings.
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 20M
Joomla default template details : rt_zephyr_j15 | author: RocketTheme, LLC | version: 1.5.0 | creationdate: August 1, 2010
Third-party SEF components: sh404sef: Installed (Version : 1.5.2.254) | ARTIO JoomSEF: Disabled or not installed | AceSEF: Disabled or not installed
Last edit: 15 years 8 months ago by eycel.
15 years 8 months ago - 15 years 8 months ago #88962 by sozzled
eycel wrote: I have a disapearing edit button in profile. The button works alright if you click it fast enough but it disapears after so long. I read through the thread "kunena problems with javascrip 93 page thread" but I didnt find any solution and thought maybee someone has one for me.
We summarised the 93-page discussion that you referred to into one message! Please read msg #1 of If you are having problems with K 1.6, please read this first
When I looked through the 930 messages in [Merged topic]The great Mootools/Javascript conflict discussion one of the consistent causes that resulted in people not getting quick responses to their problems (and also one of the causes, I imagine, of people's increasing frustration even though 99.5% of the problems have nothing at all to do with Kunena) is because people did not include their K 1.6 configuration report when they asked for help, either! :whistle:
Yes, rt_zephyr template - known issue - solved by Rockettheme at their website.
15 years 8 months ago - 15 years 8 months ago #88963 by eycel
No links? no additional information?
15 years 8 months ago #88964 by sozzled
eycel wrote: No links? no additional information?
Time to create page: 0.178 seconds
