To clarify your question further, are you not getting the "file open" dialog appearing when you click the Browse button when you try to upload an attachment or a photo (image)?
Correct. When I click on "Browse" nothing happens. I can start a new thread if you feel this is not sufficiently related to the posted issue.
I will look at setting up SEO, I have had significant trouble with this on anther site and have generally left this as the Joomla default since.Further, I recommend that you read how to properly setup Joomla SEO.
- da21f8a1397f7a5fc3ca78b7
- Banned
Xillibit, Sozzled, thanks for your replies.
I still haven't figured out what's wrong with the template itself, but server has really bad settings...
I'm puzzled, it worked on even more complex templates and that's strange it doesn't work on this one. Looks like I'll have to look into this trouble myself.
Thanks for pointing me into the right place. I'll try digging up the template's code
Show announcements is on, two moderator ID's (mine and another admin) are defined. There appears to be no way to add announcements.
Any help would be appreciated.
Thanks,
Andrew
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 256M
Joomla default template details : rt_panacea_j15 | author: RocketTheme, LLC | version: 1.5.5 | creationdate: November 15, 2010
board_title NMBA Discussion board_offline 0 board_ofset 0.00 offline_message <h2>The Forum is currently offline for maintenance.</h2>
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 100 messages_per_page_search 15 showhistory 1 historylimit 100 shownew 1 jmambot 1 disemoticons 1 template default showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62,85 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 0 showkarma 0 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 0 maxsubject 50 maxsig 300 regonly 1 changename 0 pubwrite 0 floodprotection 0 mailmod 1 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 0 allowavatargallery 0 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes doc,docx,txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 2000 showranking 0 rankimages 0 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 0 userlist_avatar 0 userlist_name 0 userlist_username 1 userlist_posts 0 userlist_karma 0 userlist_email 0 userlist_usertype 0 userlist_joindate 0 userlist_lastvisitdate 0 userlist_userhits 0 latestcategory 0 showstats 0 showwhoisonline 0 showgenstats 0 showpopuserstats 0 popusercount 5 showpopsubjectstats 0 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 144 help_infb 1 help_cid 143 showspoilertag 0 showvideotag 0 showebaytag 0 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 0 autoembedebay 0 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type post rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 0 showfileforguest 0 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 0 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 0 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access communitybuilder integration_login communitybuilder integration_avatar none integration_profile communitybuilder integration_private none integration_activity communitybuilder boxghostmessage 0 userdeletetmessage 2 latestcategory_in 1 topicicons 1 onlineusers 0 debug 0 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 0 showpopthankyoustats 0 popthankscount 5 mod_see_deleted 1 bbcode_img_secure text listcat_show_moderators 0 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Installed (Version : 1.4) | Jomsocial: Disabled or not installed | UddeIm: Disabled or not installed
It would also help if you implemented Search Engine Optimisation (SEO) at your website. It's not difficult (if you carefully follow the instructions) and only takes a minute or two to implement.
Once on the site, you'll have to login as it's for members only. Try tester/tester
Many thanks!
A
