15 years 7 months ago #92463 by sozzled
sozzled wrote: Can you please tell us what version of Joomla you are using?
15 years 7 months ago #92467 by mychatta
I use the version 1.5.22..... I installed the emoticons and it worked the same one day to another has disappeared.
Videochat gratis senza registrazione , gratuita e italiana.
www.mychatta.net/
15 years 7 months ago #92468 by sozzled
Thank you for this important information. The answer to your question is contained in msg #1 in this topic. :)
The following user(s) said Thank You: mychatta
15 years 7 months ago #92470 by honestloez
Hi, i have been building Joomla site with this template: Corona, from YOOtheme. After i've done the site from localhost, i noticce that there are some symptoms that i have a conflict with mootools. When i change the template, kunena just work really perfect. But when i activate the Corona template, i cannot click the BBcode, cannot see my profile, etc. I know that the easiest way is change the template, but i already finish the site using this template and i really appreciate when there is another solution beside it.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : yoo_corona | author: YOOtheme | version: 5.5.0 | creationdate: March 2011
Kunena default template details : Example Template | author: Kunena Team | version: 1.6.3 | creationdate: 2011-01-31
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 2.2.1) | UddeIm: Disabled or not installed
Plugins: System - Mootools12: Disabled | System - Mootools Upgrade: Enabled | JFirePHP: Disabled or not installed | Kunena Discuss: Disabled or not installed | Kunena Search: Disabled or not installed | My Kunena Forum Menu: Enabled (Version : 1.6.2) | My Kunena Forum Posts: Enabled (Version : 1.6.0-RC1)
Modules: Kunena Latest: Enabled (Version : 1.6.2) | Kunena Stats: Enabled (Version : 1.6.2) | Kunena Login: Disabled or not installed
15 years 7 months ago #92475 by sozzled
G'day, honestloez, and welcome to Kunena.
Please read msg #1 in this topic. Thank you.
15 years 7 months ago #92481 by mychatta
Replied by mychatta on topic ?????
Sorry but i dont understand .. where are the answer ?
www.mychatta.net/
Time to create page: 0.188 seconds
