Merged Loading BBCode editor...
13 years 3 months ago #144665 by Never-in-Doubt
Hi
Just read this --> www.kunena.org/forum/K20-Test-Reports/12...BBCode-editor#127844
I am having very similar issues in that my editor just won't load - It literally reads "Loading BBCode editor...".
My config is shown below (see I am learning lol)... :)
Any idea's - thanks.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: -1 | Max file upload: 128M
Joomla default template details : sj_plus | author: YouTech Company | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Third-party components: Jomsocial 2.8.4.1
Plugins: Search - Kunena Search 3.0.0 | Content - Kunena Discuss 3.0.0 | JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Latest 3.0.0 | Kunena Stats 3.0.0 | Kunena Login 3.0.0 | Kunena Search 3.0.0
13 years 3 months ago #144703 by hilfiger
Replied by hilfiger on topic Loading BBCode editor...
I have the same problem, did look for the problems which caused same error in v2 but i do not seem to be able to identify the source.
13 years 3 months ago #144706 by Never-in-Doubt
hilfiger wrote: I have the same problem, did look for the problems which caused same error in v2 but i do not seem to be able to identify the source.
Did the guys here not help? Have you got a thread?
I found with my earlier issues that the support here is actually pretty good, once you alert the right people to the threads existence they are pretty damned good.
I am working on some issues of my own, testing various angles of JS disabling but that isn't helping much either really.
Help....! :)
13 years 3 months ago - 13 years 3 months ago #144707 by Never-in-Doubt
If I turn the site offline, everything works again. How strange.....
Last edit: 13 years 3 months ago by Never-in-Doubt.
13 years 3 months ago #144708 by Never-in-Doubt
Solution found I think --> www.kunena.org/forum/K-2-0-General-Quest...itor?start=20#133131
However we cannot turn off the YT framework when we use 'smartaddons' themes! That's bonkers to even suggest that we disable the YT Framework. Is there a workaround that allows Kunena to be compatible with YT Framework?
Thanks as always :)
13 years 3 months ago #144717 by hilfiger
I did try all option, my template maker just told me that they do not support kunena. So i am in the same situation as others who use not so good templates.
Time to create page: 0.266 seconds
