Merged Loading BBCode editor...
11 years 9 months ago - 11 years 9 months ago #162189 by sozzled
Replied by sozzled on topic Loading BBCode editor...
emeyer wrote: Also it loads the non-minified version of editor.js by default. I think it should load the minified version.
Please read Minified CSS in the Wiki. If you are running Kunena with the debug option turned on, you will load the non-minified version of CSS and, possibly, of Javascript scripts, too. I am not sure about minified/non-minified Javascript scripts and Kunena. Sorry, I can't help you much with that.
Last edit: 11 years 9 months ago by sozzled.
11 years 8 months ago #162290 by emeyer
Replied by emeyer on topic Loading BBCode editor...
Thank you for your comment, but nothing I wrote was intended to refer to CSS. It is the javascript on which I was commenting, about which you note your own comment does not apply anyway.
11 years 8 months ago - 11 years 8 months ago #162395 by xillibit
Replied by xillibit on topic Loading BBCode editor...
emeyer wrote: Just to let others know, it appears 3.07 DOES require jquery, contrary to what the release notes say, for the editor to work on Joomla 3.3.6. This seems to be because the editor calls a script called 'validate.js' which works with jquery 1.2.5 +.
I was able to get it to work more quickly by disabling jquery in the main template a\and adding the following line to the blue eagle template's 'initialize.php' file, just before its call to
$template->loadMootools.
$document->addScript(' code.jquery.com/jquery-1.3.2.min.js ');
The editor js file of Kunena 3.0.7 still require Mootools like it's specified in readme, you need to check if you a javascript conflict
Last edit: 11 years 8 months ago by xillibit.
11 years 8 months ago #162469 by emeyer
please excuse me for saying, but mootools and jquery are different, so you need to think a little whether you know enough before posting on such topics.
11 years 8 months ago - 11 years 8 months ago #162512 by xillibit
You had said that the Kunena editor laods itself the validate.js file but i had answered that isn't correct and Kunena doesn't by itself the validate.js file
$document->addScript('code.jquery.com/jquery-1.3.2.min.js');
Why you load an obsolete version of jQuery ?
