Merged Loading BBCode editor...
13 years 2 weeks ago #149992 by Youganov
Replied by Youganov on topic Loading BBCode editor...
Sorry to dig up this topic, but I still have not find any solution to my issue, any help?
Thank you in advance,
Ystvan
13 years 2 weeks ago #149997 by sozzled
Replied by sozzled on topic Loading BBCode editor...
Upgrade to K 3.0.3 and use the K 3.0.3 Blue Eagle template.
12 years 11 months ago #151463 by pekka
Replied by pekka on topic Loading BBCode editor...
Hi!
I have K 3.0.3 and I'm using Blue Eagle template and I'm still getting "Loading BBCode Editor.." even in my almost out-of-the-box sandbox.
I discovered that if I change Joomla 3.2 template from Beez3 to Protostar, Kunena BBCode editor works fine. Any ideas what is causing the problem with Beez3 template?
12 years 11 months ago #151479 by coder4life
Replied by coder4life on topic Loading BBCode editor...
The only thing I can think off at the top of my head is that certain Javascript Libraries are not loaded in Beez3. I would highly suggest not using those versions of the template other than Protostar as I heard there are issues that have not been fully worked out with those distributed versions.
12 years 11 months ago #151532 by pekka
Any advice how to trace which javascript is missing? I would really like to get this working with Beez3 template, because this is the only problem I have found with the template and I have used dozens of hours tweeking the frontend.
12 years 11 months ago #151568 by Matias
Replied by Matias on topic Loading BBCode editor...
Enabling debug mode in Joomla might help. Kunena has small JS script on debug that checks some of the basics.
Time to create page: 0.150 seconds
