Merged Loading BBCode editor...
12 years 11 months ago #151658 by rich
Have you updated your allrounder template and others extensions also? Could you please post your Kunena Configuration Report as it will help diagnose the issue.
12 years 11 months ago #151660 by waanie
htaccess: Exists | PHP environment: Max execution time: 3600 seconds | Max execution memory: 64M | Max file upload: 2000M
Joomla default template details : ALLROUNDER-j1.6 | author: Juergen Koller | version: 1.4 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: UddeIM 2.9
Plugins: None
Modules: Kunena Latest 3.0.1
12 years 11 months ago #151661 by rich
Please try following. Go in backend to "Extensions > Plugins > System - JCH Optimize". Maybe it helps if you set "Defer javascript = No".
12 years 11 months ago #151666 by waanie
rich wrote: Please try following. Go in backend to "Extensions > Plugins > System - JCH Optimize". Maybe it helps if you set "Defer javascript = No".
Thanks for the quick reply. That didn't fix it yet. should I clear the cache after I make a change?
12 years 11 months ago #151668 by waanie
Thank you
I tested some more and I got it working by disabeling the combine javascript files and disabling defer javascript
that is great
you guys are amazing
12 years 10 months ago #152001 by positivnrg
Ok as I see, this is a strange problem...
My story: Everything was fine, and everything was working until 2 hours ago. I did nothing with any settings, I just filled up Kunena with sections and categories, and made a new user group in J! for moderators. And when I wanted to try my moderator test account on the site, I got the "Loading BBCode editor..." message.
As I said, 2-3 hours earlier everything was fine.
It is funny, my site starting tomorrow evening. :)
PS.: No I won't change my template. I Used it with many sites and worked fine with Kunena.
My settings:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 24M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 2.5.5 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.4 | creationdate: 2013-12-22
Kunena version detailed: Kunena 3.0.4 | 2013-12-22 [ Ukko ]
Third-party components: AlphaUserPoints 1.9.3 | UddeIM 3.2
Plugins: Content - Kunena Discuss 3.0.1
Modules: Kunena Latest 3.0.1 | Kunena Stats 3.0.1 | Kunena Login 3.0.1
Time to create page: 0.193 seconds
