Solved K 2.0.2, K 2.0.3: problems with preview
13 years 9 months ago - 13 years 9 months ago #140155 by demka
Hi. Today I have updated, and still does not work preview. Tried to install the code, but neither of which did not work.
previewRequest = new Request.JSON({url: "<?php echo KunenaRoute::_('index.php?option=com_kunena&view=topic&layout=edit&format=raw');?>", onSuccess: function(response){ var __message = document.id("kbbcode-preview"); if (__message) { __message.set("html", response.preview); __message.fireEvent('updated'); } }}).post({body: document.id("kbbcode-message").get("value") });
Last edit: 13 years 9 months ago by demka.
13 years 9 months ago #140163 by sozzled
demka: this topic related to K 2.0.2 and K 2.0.3. Are you saying that today you updated to one of these two versions? Can we please see your Kunena configuration report? Thank you.
13 years 9 months ago #140171 by demka
version 2.0.4 . Topic no, the problem remained.
13 years 9 months ago #140173 by sozzled
I asked for your configuration report. You don't have to give us your configuration report, if you don't want to do that. On the other. Hand, without your configuration report, we no nothing.
13 years 9 months ago - 13 years 9 months ago #140194 by demka
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 5M
Joomla default template details : kontrast | author: | version: 1.0 | creationdate: 2012-11-19
Third-party components: Jomsocial 2.8
Plugins: Search - Kunena Search 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Latest 2.0.4 | Kunena Login 2.0.4 | Kunena Search 2.0.4
13 years 9 months ago - 13 years 9 months ago #140198 by sozzled
Thank you.
We had a similar discussion ( Major Problem Saving OR Editing Posts ) from one user who solved his problem by changing to a different webhosting service provider. It may be the same in your case, too.
Because you edited your post and removed parts of your configuration report from the message, there is nothing more that I can suggest to you. It looks like you have a problem but I do not know how to help you if you edit your configuration report and remove parts of it.
Last edit: 13 years 9 months ago by sozzled.
Time to create page: 0.157 seconds
